![]() Drives: 2018 zl1 Join Date: May 2015
will this fit?
will the granatelli pro stock wing (http://www.phastekperformance.com/20...aro-500066.htm) fit on a 2015 camaro?
![]() ![]() ![]() ![]() Drives: 2011 2SS Join Date: Mar 2015
It looks like it will. I've seen one camaro with that spoiler. Apparently it uses the stock holes so you should be good
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
#3 | |
Ad says 2010 thru 2013. |
![]() Drives: 2014 Camaro 2SS 1LE /2011 2LT Join Date: Sep 2015
Do it with Dan LOL. He has the same spoiler, for a 13 tho.
Instagram: Sangstah
Probably won't work with a 2015, different trunk
#6 |
![]() Drives: 2010 1SS RS M6 Join Date: Jan 2015
Pretty sure 14 and 15 trunks are different ...
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
#7 |
![]() ![]() Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
Clearly the website says 2010-13, and you have a 2015. So, in my opinion brown walls contrast with 5/16" driver.
Stupid questions get stupid answers. |
#8 |
![]() Drives: 2015 Topless Btch RS Join Date: Mar 2016
2SS has the RS package......no?
#9 |
2011 SS L99
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
#11 |
![]() Drives: 2012 Camaro 1LS w/L99/TR6060 Join Date: Dec 2012
![]() ![]() ![]() at these responses Sent from my iPhone using Tapatalk |
