2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
Another dss failure
Went to track last night on nitto 555r's and thinking things are good finally maybe the 7th set of axles would be key 1 set too short and broke were to long and too short. 1 year 3 months later I finally get car back missed sema last year.
1'st pass launch 3600 and bog and tried too run out door without shifting at end. So next pass I switch lanes. I launch at 4500 it spins I let out no wheel hop I get traction I floor it and drive shaft shop 1400 axle completely breaks in half. Also tires are 20's. Half the power. And blow up! 350 tow bill tow truck driver catches ground effects and tears off bumper. What a night. I learned lesson dss is still garbage and get a car hauler
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
![]() ![]() ![]() ![]() Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Hard to follow your post as written.
Perhaps your approach is too aggressive for the available parts? 20" nittos are hard and have no ability to absorb impact from launches. High RPM launches aren't helping and not advised on a car driven to the track. The suspension and bushing upgrades are helpful except that they further reduce the car's ability to absorb the launch impact and at some point a weak link will give out. In this case the axles (7 times now?). I would suggest you go to a Mickey Thompson (preferably the softest drag radial or better yet a slick) and in a smaller wheel size. This will absorb the impact of the launch and may allow the axles to live the way you are driving it? |
2010 transformer
The half shafts were all different sizes only one half shaft the driveshaft on a shift not a launch
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto Join Date: Apr 2011
As mentioned above, you are being way to aggressive on the launch with crappy tires.
If you started out spinning, why would you then decide to floor it when you hooked? The suspension and drivetrain went from completely loaded to unloaded to loaded again and potentially at an angle depending if one wheel was hooked and the other spinning. Is you car lowered on the coilovers or does it have lowering springs? This can severely impact the axle angle which is a manufacturing flaw on these cars to start with. I have over a 500 passes on DSS parts with a lot more power and the only failure was a torn boot back in the early days. Not necessarily DSS fault as it could have happened during installation. Of course, maybe your just that unlucky and keep getting every bad one or maybe someone does not know how to install them. |
Just going to leave this here for you to think about before you start bashing a vendor for a failure. I am lowered 1 1/4", I have STOCK axles and driveshaft, I'm on a 315/30/18 drag radial with very little sidewall and I launch at 5000 minimum. I don't break axles. I also 60' in the 1.50's M6 car.
What I'm getting at is, it's more than likely your technique that is hindering your success. I have all the wrong things going for me from what the internet says and yet I have a way of making it all work. More than one way to skin a cat.......
#6 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
#7 | |
#8 |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
I managed to dead hook my car at Lucas Oil on a 6,000 rpm launch, my DSS axles and nine inch never made a peep, though I twisted a 300M input shaft as well as the 300M main shaft...
I also run the 1400 hp axles in standing mile events throwing in excess of 2000 hp at them, with never an issue... I hate to say it but agreeing with the others I believe it's more of a technique (driver) or installation (installer) issue.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#9 |
![]() Drives: 2015 Camaro 1LE Join Date: Jun 2016
Try slipping the clutch instead of dumping it
#10 |
2010 transformer
It was a 2-3 shift
#11 |
In The Circle
I really don't know whats going on with your deal, but I launch at 4800 on a 2-step can't get more brutal then that on driveline parts. Although I have a 9" still have the same 1400 HP axels.
#12 |
In The Circle
1 question do you remove the ABS fuse and relay? That's the only real way to turn the traction control OFF.
#13 |
Merc, just last week I ran my car for the first time in a long time due to replacing the pumpkin because of failure. I launched my car on the first run and snapped the stock driver side axle. I didn't dump the clutch but it snapped the axle anyway, so after reading your comment you are saying even though I had traction control off I should have pulled the fuse? I'm trying to learn is why I'm asking. I'm used to old school track cars so I'm trying to learn the tricks of the computer cars.
#14 |
2010 transformer
Yes I am confused a little
