Old 10-02-2016, 09:07 PM   #1
GhostRider15
Drives: 15' Camaro ZL1 Supercharged M6
Question ZL1 5GEN ... Power Shuts Down.... NO Warning???
Anyone have this happen with thier ZL1. Mine is a 2015 with only 7400 miles. The stability control light starts flashing and car loses power and shuts down. Wait a few minutes then starts back up request you roll down and up both windows. Did it 4x yesterday 10/01/16 trying to get back home. First time after starting back up check engine light came on but didn't come back on after turning off normal and starting back up normal. Really no warning so glad I wasn't trying to make a turn across oncoming traffic..... maybe a ECM, Stability Tract component, or Throttle body failure?
GhostRider15 is offline   Reply With Quote
Old 10-02-2016, 09:32 PM   #2
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
any mods?
SSmokinSS is offline   Reply With Quote
Old 10-02-2016, 09:42 PM   #3
GhostRider15
Just a CAI Cold Air Intake system back in August 2016.
Old 10-02-2016, 10:56 PM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
how is battery voltage?
could possibly be a bad ECM otherwise.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 10-02-2016, 11:02 PM   #5
GhostRider15
voltage slightly over 12 once restarted and running "normal". I was wondering if it was the ECM too. Thanks for the feedback. Dealer can't get me in until Thursday at this point. Going to try to limp it up to Advanced Automotive to get a code reading but the check engine light isn't on anymore. I assume codes will have already been captured.
Old 10-02-2016, 11:03 PM   #6
fluxzl1
Drives: 2015 ZL1
bad ground??
fluxzl1 is offline   Reply With Quote
Old 10-02-2016, 11:50 PM   #7
GhostRider15
I hope to know more after I get the codes pulled tomorrow. I'll post them when I get them. Thanks.
Old 10-03-2016, 01:47 AM   #8
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Most likely ECM. I had the same issues and they replaced it. Many others have had similar experience. A CAI could give you a check engine light if it requires a tune. But if it is a no tune not likely unless you combine it with headers and maybe a throttle body. Then it wants a tune.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-03-2016, 10:35 AM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Simple issue....bad ground from changing your CAI.
Bigger issue....bad ECU which the dealer will have to fix.
good luck.
Mods:
Old 10-03-2016, 09:39 PM   #10
GhostRider15
Well took it up to Auto Zone for the codes to be read and surprisingly no codes showed up. My service manager at the dealer said that it may be a bad battery cell due to shutting down and then the window's request reprograming each time. Auto Zone did a battery check and I think it was a circuit check but again everything came back good. I started to leave to drive straight to the dealer and what do you know the car just cut off but radio and mylink display stayed powered up. I had the wife run in and have the guy bring code reader back out without doing anything before plugging it in. Still no codes showed. Car would not turn over at all. We decided to check the fuses and found a blown fuse #22 a 20 amp fuse that dealt with the brakes. We replaced it started up. Took to dealership without shutting off in hopes they can find something or at least reflash the ECM to update it. Stumped.....
Old 10-03-2016, 09:50 PM   #11
GhostRider15
I changed the OEM AI out back the first week in August 2016 about two weeks after I bought it. Would it show up this late after install. We got the Cold Air Inductions CAI that was very simple to install. Said it didn't need a tune but I do want to have one done. I bought a SCT X4 7416 model but when I went to install it said it was not supported on my 2015 ZL1. I thought I had researched it pretty well and the amazon compatibility system said it was good. After it said it wasn't supporting my car I did a search again and eBay's system said it was not compatible so go figure. Luckily they had me send it back so just waiting on a refund. Once I get this issue straight I plan to take it to the Maryland International Raceway and have them do a dyno pull and tune it. Hopefully that will work any bugs out.
Old 10-04-2016, 09:43 AM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Sounds like a bad ground to me.
Double check your CAI install.
Mods:
Old 10-04-2016, 09:50 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
Loose battery cables and or connections, you will not find this through the OBD2 port you must start looking and tugging on the cables and grounds.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-04-2016, 11:04 AM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
check the firewall connection on the driver's side also. It is a big black plug that may be loose.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
ecm, power, stability control, throttle body, zl1
