Old 10-11-2009, 06:27 PM   #1
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Fuse Pull?
I was reading about the fuse pull for the v8 engine and was wondering if anyone tried it for the V6?
tradosaurus is offline   Reply With Quote
Old 10-11-2009, 06:40 PM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
No real benefit on our cars, like for the SS guys... That being said I did it yesterday to verify that pulling 5 and 20 would reset the ECU without losing all the other settings for things like the stereo, windows, tires, etc. And it worked... car kept all it's settings..
scrming is offline   Reply With Quote
Old 10-11-2009, 06:48 PM   #3
tradosaurus
Thanks. I'll mark that off of my "to do" list when I get my Camaro.
Old 10-12-2009, 06:24 AM   #4
Scott@Bjorn3D
V-6 is ment to run on 87 octane so nothing for you guys. It was my V8 that we found the problem when dealer filled it up with 87 octane. The car would not learn to use the 93 octane table. GM even sent engineers down here to fix my car and the reset the octane tables.
I figured out the same thing could be done pulling the fuses and got my bodies car PQ running right with the pull. That is what started the old fuse pull.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-12-2009, 09:59 AM   #5
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
That's very intresting.................
97one is offline   Reply With Quote
Old 10-14-2009, 05:26 PM   #6
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
Im going to use this trick for installing my cai.
i007spectre is offline   Reply With Quote
Old 10-14-2009, 05:28 PM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
what if your dealer first put 91 0r a higher octance then 87, and now all you do is put 87, would the fuse pull work in that scenario?
Fuse Pull on LS3? Atomic Autosports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 49 08-06-2010 10:37 PM
drag strip after fuse pull AntiVnm Dragstrip and Launch Techniques Discussion 14 11-01-2009 07:41 PM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 03:44 PM
Anyone tried a Fuse Pull on LS3 95RedCamaroz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-12-2009 02:33 PM
8327 after fuse pull redjewel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 08-25-2009 03:24 PM
