![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
what cylinder heads for 1000whp
what cylinder heads should I run for my new setup?
I'm leaning towards a set of lsa heads for the thicker casting? should I run them as cast or do I need to have them ported to get rid of the "batwing" in the intake runners? plus should I have inconel exhaust valves added? or even cheaper yet, reusing my gmpp ported ls3s? just don't want issues and would like to hold a headgasket at this power level. my head is spinning(can you tell?) 408-416ci twin garrett 6265s e85
I'm running my stock LS3 heads with ls9 gaskets and ARP studs. Hard to get quality information sometimes on forums just because people seem to think if it's not a built LSX it won't make 1000+whp.
Are the ls3 heads optimal for 1000whp? Not really they do have much better options if money is no issue. A couple Camaros here are at the 1000whp mark on stock bottom end still. I'll be other 1000whp but 98% of the time it will be turned down because let's face it. 1000whp and 4000lbs is going to have traction problems. Lol If your budget allows for better heads go for it. If not keep what you have just add ls9 gaskets and ARP studs at the minimal.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Get the stock head's dykm'd to check for cracks first....then deck'd for a nice flat surface, new solid valves with valve job, (if you can get the chamber volumes equalized), basic port match on intake/exhaust and as mentioned above LS9 hd gasket and studs...solid investment of monies and extra funds go to any drive train issues that arise(and they will with that HP!!!!!)
have fun..stay safe...peace out...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
If budget allows LSA/ls9 heads are a great upgrade. Get a mild port job, proper valves and springs. That is one area that you should spend money in.
While stock heads can work, long term reliability and safety factor is much lower. If you can't afford a cheap set of LSA heads, you can't afford 1000rwhp.
Nick
Corvette Z06 -1200ish rwhp |
#6 | |
#7 |
Well if I had a barrel of cash then lol...OP did state cheaper alternative...only lookin at the 2010 twin turbo camaro runnin 7's with stock LS3 heads....seems they hold up ok there...
#8 | |
and I was looking for answers from people that have first hand experience with cars of this caliber
#9 |
well excuse me...
#10 |
oh and btw - you have no clue about my exper...if you based it on my sig? rofl...30+ years hands on auto plus common sense equals = you get the pic...peace out
#11 | |
Nick
#12 | |
#13 |
![]() ![]() Drives: 2010 Camaro 454 LSX (SOLD) Join Date: Jun 2013
We have plenty of Camaro Head options to suit your 1000hp+ build!
Our Powerstorm GM LSA Race Series heads are built with the highest quality components on the market to date! These head packages are built around Livernois years of racing experience and combine all the knowledge of our extensive development background as well. This is how we're able to offer cylinder head packages that are unmatched in their performance. What you'll find with this head: 5 axis CNC machined Fully assembled Custom valve job Upgraded stainless steel intake & exhaust valves Upgraded springs Upgraded retainers, locks and seals GM Guide Available HERE!http://www.livernoismotorsports.com/product/LPP761108 Combining this head with our Inconel Exhaust Valve Upgrade, you'll be putting down the power in no time. We also have our LSX - LS9 Race Heads that would do a great job as well! For any other questions, give us a call at (313)-561-5500 ext: 1 or email us at info@livernoismotorsports.com |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
I have the LSA heads with a port and polish job done by ADM. It's a good set up.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
