Old 10-10-2016, 08:34 PM   #1
2010SailorsSS
CamaroInProgress
Drives: 2010 black on black SS
Sudden temporary loss of P/S
Yesterday as I'm looking for a parking spot in a parking garage, i experienced a very sudden yet temporary loss of power steering. After parking i looked for any leaks and found none. I checked fluid level which was also fine. Fluid didn't look dirty but that's just what i could see I the on the dip stick and in the top of the reservoir. I did some quick research and learned it could either be a loose power steering belt or burnt out pump. Is this true?
Today again as I'm pulling out of said garage it briefly happened again. I tried to recreate the scenario in an empty parking lot and it didn't happen. I drove around for 30ish miles at various speeds and nothing happened, steering feel was fine.
Someone please help! I'll admit I'm not the most knowledgeable. Is it the pump, belt, or something else?
2010SailorsSS is offline   Reply With Quote
Old 10-12-2016, 05:01 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
if the belts not squeaking it's probably not it. is the pump making any noise? did you also drop in RPM to almost stalling? that can do it.
JCunningham is offline   Reply With Quote
2010 camaro ss, power steering
