Old 10-13-2016, 10:08 AM   #1
PatrikD
Drives: Camaro 6g, Corvette GrandSport 17
Question Z/28 - EU homologation
Hello.. im looking for solution. I would love to get z/28 but first i need to know if there is anyone that went thru EU homologation of this car.
Do you know if it is possible to switch lights with classic EU spec. E lights ? If they fit from "classic" EU spec Camaro.
I know there is still problem with wiring but i hope you guys can help me get it done.
Thank you, and sorry if there is any thread with this kind of problem.
PatrikD is offline   Reply With Quote
Old 10-13-2016, 10:20 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
if people in Australia can make a right hand drive Camaro 5th gen and make everything work, this issue shouldn't be a big problem. With the Z/28, nothing is special about the body panels near the lights so Euro spec lights with the amber turn signals and such should be a direct fit. It appears after a quick google search the SS/ZL1 lights with the LED panels are Euro spec.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-14-2016, 04:07 AM   #3
Harryoz
Harryoz's Avatar
Drives: .
I imported my Z/28 to Luxembourg via a specialist US car importer and had it registered here - only minor changes required I recall
Harryoz is offline   Reply With Quote
Old 10-14-2016, 05:36 AM   #4
RichSS2006
RichSS2006's Avatar
Drives: 2010 2SSRS
Check the UK regional threads. They have a bunch of Camaros in the U.K. Both EU and US spec cars. They've written about the process several times.
Good luck
No longer stock, but oooh so much more fun!
RichSS2006 is offline   Reply With Quote
Old 10-14-2016, 09:38 AM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Any thing you want can be done, we have all ZL1 headlights and tail lights on the shop Z/28
Old 09-03-2018, 06:32 AM   #6
Jberg805
Drives: N/A
Just installed Eur.spec LED taillights on my Z/28 with a harness from Gen5 DIY. Rear light, turnsignals, brake and reverse works fine. But when I turn the hazard flash on it flashes the brakelights instead of the amber turnsignals. Was hoping it was basically plug and play, but seems I will be spending some more time in the shop with this. Also the right hand turn signal flashes rapidly, might just be the resistor that is broken?
Jberg805 is offline   Reply With Quote
Old 09-05-2018, 01:25 AM   #7
1erMQP
1erMQP's Avatar
Drives: 15 Z/28 #605
Hi Jberg805,
have you used a trailer module to divide the combined turn-brake-sinal ?
Unfortunately will not work
You can find my experiences in that topic from post #31 onwards:
https://www.camaro5.com/forums/showt...=europe&page=3
1erMQP is offline   Reply With Quote
Old 09-05-2018, 01:48 AM   #8
Jberg805
Drives: N/A
I’ve been looking for that post.. thank You
europe, homologation, z/28
