Old 10-12-2009, 10:54 AM   #1
buelldude
car enthusiasts
buelldude's Avatar
Drives: 2012 2SS
hard to start, when warm?
I have a new one, I have a hard time starting my car after its been shut off for a few mins? I hope to get this out right so you know what I'm dealing with. I start the car first thing in the morning, everything is good. I drive to anyplace and shut it off, no it doesn't have to be up to temp for this to happen. I get back in the car and try to start it, it starts real hard (sometimes doesn't start at all). I will try to start it again (turn key all the way off) and she fires up?????? Does this sound or make any sense? If I wait sometime before starting it again it seems to be ok also.
So there you have it, I wanted to try here before I go to the dealer for a fix.
This has been going on for about a month, it just keeps getting harder and harder to start. I did put on a new exhaust but it was doing it before that was done.
<img src=http://www.camaro5.com/forums/album.php?albumid=9196&pictureid=93608 border=0 alt= />
buelldude is offline   Reply With Quote
Old 10-12-2009, 11:03 AM   #2
Blood
Blood's Avatar
Drives: 2003 Silverado z71 1500
Maybe its the starter? Sounds like could be a wire connection.
Blood is offline   Reply With Quote
Old 10-12-2009, 01:12 PM   #3
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
When you say it wont start at all is the engine turing over or does it act like it is dead??
WICKEDSS is offline   Reply With Quote
Old 10-12-2009, 02:10 PM   #4
buelldude
car enthusiasts
buelldude's Avatar
Drives: 2012 2SS
it turns over fine, when it acts as if its going to start its almost like it has no fuel. When you let go of the key it acts like you should have held on for a bit longer. start it the same way when its cold and it fires right up?
Old 10-12-2009, 06:40 PM   #5
NVMY68SS
Drives #296
NVMY68SS's Avatar
Drives: 1968 Camaro SS - 350/5 Speed
I've noticed this a couple of times too. Not sure why either. Turns over fine, but it acts like something is holding it back. And I agree, it only does it after I run in somewhere for just a few minutes.
#296 Delivered 6-1-09 Dynoed 10-3-09 384.56HP 387.65TQ with the bolt-ons listed, no tune.....yet!
Roto-Fab CAI (Install pics here), Doug Thorley Shorties, Flowmaster American Thunder 409S Cat Back Vid
NVMY68SS is offline   Reply With Quote
Old 10-12-2009, 07:38 PM   #6
buelldude
car enthusiasts
buelldude's Avatar
Drives: 2012 2SS
after the car cools off (cold) it starts fine????
Old 10-14-2009, 12:24 PM   #7
ffrcobra_65
heat soak. It happens only after you shut the car off after driving, let car sit for a little while, re-start it and it may take a couple of cranks to get it fired up. No problem.
BTW, you don't need to hold the key all the way to the right, just turn the key to crank and let go. The engine will crank on its own.
Old 10-14-2009, 12:45 PM   #8
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
I have the automatic but only 350 miles and have not had the problem yet and hope that I never do.
Dave Coyle is offline   Reply With Quote
Old 10-14-2009, 02:50 PM   #9
PsyDoc
Drives: Soon-to-be 1st Gen
I thought heat soak was an issue when your turned the key and "nadda." In other words, the starter will not turn at all due to being "soaked" in the heat from the engine bay. To the OP, have you looked to see if the heat shield is in place?
PsyDoc is offline   Reply With Quote
Old 10-14-2009, 05:01 PM   #10
ffrcobra_65
It seems the OP is able to crank the engine, but the engine doesn't fire up right away. If you are able to crank the engine, the starter is fine....unless it cranks weak then yes, starter or connection could be an issue. I own 2 carburated cars and heat soak/vapor lock is a PITA. crank crank crank, pedal to the floor to get the hot fuel through and cool fuel in, then fires up. I understand you don't have to floor the go pedal when restarting EFI cars, but heat soak does not discriminate. I had a EFI car that I plumbed the gas line too close to the headers..well, re-starting was never a 1 try deal.
FWIW, my SS takes 2-4 seconds to fire up. My 2008 Suburban is the same way. My 2007 Accord fires up in 1/2 second.
Goodluck OP.
Old 10-14-2009, 05:53 PM   #11
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
I've seen other cars do this due to the gas cap not being tightened all the way or having a bad cap. Make sure you have turned it tight enough to make it CLICK. Just a guess, but worth looking at.
OBSSEST is offline   Reply With Quote
Old 10-14-2009, 10:59 PM   #12
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I heard of vapor lock on carbureted engines. The fuel near the engine would actually be in vapor state and when trying to crank the vapor would just act like a spring and compress and expand with the pump cycles so the fuel would not move, the vapor bubble would just bounce back and forth for a bit until it got worked along. Once the engine cooled down the vapor would condense back to a liquid so it would start fine. If that were the case, try to turn your key to the run position to let the fuel pump run for a few seconds and then try cranking.
HeavyD is offline   Reply With Quote
Old 06-22-2011, 09:26 AM   #13
epstein
Drives: SS/RS
Send a message via AIM to epstein
Has anyone checked their Fule pressure when this Happens????
epstein is offline   Reply With Quote
Old 10-27-2011, 04:54 AM   #14
buelldude
car enthusiasts
buelldude's Avatar
Drives: 2012 2SS
Sorry for the slow reply
I have no idea what they are checking when it goes into the shop.
update, still can't find anything. Here is more info
http://www.camaro5.com/forums/showthread.php?t=153371
Remote Start on Manual Transmission Dentyneice Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 51 02-11-2015 01:56 PM
Body In White Camaro bodies are ready to start shipping Robin Lawrence 5th Gen Camaro SS LS LT General Discussions 37 10-16-2009 12:25 PM
Jays off to Impressive Start bluch Canada 20 09-21-2009 07:28 PM
96 trans am won't start drayton_cross 4th Generation Camaros 0 04-24-2009 09:33 PM
