Old 10-14-2016, 09:20 PM   #1
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Is E85 the way to go for more HP?
I have been looking at trying to increase my HP close to 800 and have been advised to change over to a dual stage fuel pump, upgrade injectors and install a E-85 system. Can you guys tell me if this is a safe way to go? i've seen a few guys on the forum go this route. I still need to buy the upgraded fuel pump either way and I'm looking at getting ID 1000 injectors (If anybody has some for sale?). Do you guy's have any sugestions on which way to go after you look at my current mods, thanks.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 10-14-2016, 09:34 PM   #2
DrkPhx
DrkPhx's Avatar
Definitely the way to go to help with power especially if you're heavily modded. I recently added the DSX flex fuel kit and I love it.
Old 10-14-2016, 10:16 PM   #3
jc615
jc615's Avatar
Drives: Camaro and Sierra
i have the DSX flex fuel kit and DSX answered all questions I had. I'd give Dave a call and discuss your options with him. There shop in Austin is pretty nice
jc615 is offline   Reply With Quote
Old 10-14-2016, 10:30 PM   #4
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
E85 is awesome in these cars!
SSmokinSS is offline   Reply With Quote
Old 10-14-2016, 10:44 PM   #5
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Another DSX conversion here. E85 is a great upgrade
Deke736 is offline   Reply With Quote
Old 10-14-2016, 11:36 PM   #6
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Your mods don't show in your signature...Edit your sig. and list your mods above the pic and they will show...I would think for an 800HP build that a alcohol system would be more efficient...For those of us near 600HP E85 is a no brainer...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 10-15-2016, 08:08 AM   #7
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Stock bottom LS3 800+rwhp on E85 with a DSX flex fuel kit as well, made 700rwhp on 91 pump gas, E85= 100+ octane, more boost and more timing, I would get ID1300's for a little room to grow, I started with 1000's and made 803hp, have the 1300's now.
swiftkart is offline   Reply With Quote
Old 10-15-2016, 09:41 AM   #8
MaroSS
ZL1
MaroSS's Avatar
Drives: 10' SS/RS - Sold; 15' White ZL1
Did you guys just use the DSX kit or you upgraded the entire fuel system as well?
MaroSS is offline   Reply With Quote
Old 10-15-2016, 10:36 AM   #9
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
I went with a Fore triple pump set up when I did my latest round of mods so I could go E85. 104-107 octane. I'm at 810 to the wheels through a stalled auto on low boost. E85 is great if you have a ready supply of it available and way cheaper than paying $9/gal for 100 octane race gas. I also run meth.
mrvenicess is offline   Reply With Quote
Old 10-15-2016, 11:20 AM   #10
LSA376
LSA376's Avatar
Drives: 2013 ZL1 M6
E85 is awesome however; a few things to remember:
Cold weather affects how the engine starts and runs
Don't let the car sit over winter with a tank of E85 in it
Oil change frequency must be done at half the interval of pump gas
Other than that, the LSA loves E85
417, Callies Magnum Crank, Oliver Rods, JE Pistons, Lingenfelter Heads, Comp Cam, Magnuson Heartbeat, 28% Pulley, E-85, Squash Fuel System, Afco, Rotofab, BMR, Hotchkis, Corsa, Kooks, IDA1300's, Comp Cam, Springs, Push Rods, Trunions, Nitrous Outlet, RPM 6-point cage, garage built
LSA376 is offline   Reply With Quote
Old 10-15-2016, 12:12 PM   #11
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2022 Silverado ZR2
DSX flex fuel kit, E85, and a good tune.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 10-15-2016, 10:39 PM   #12
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
Still on stock Cubes?? one of the highest Whp numbers I've seen for boost only. Especially through an Auto... Impressive if so
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 10-15-2016, 10:40 PM   #13
ZL1Kid_AL
ZL1Kid_AL's Avatar
Definitely get some corn. Whole different car on E vs 91-93
Old 10-16-2016, 02:29 PM   #14
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
how much for a kit?
Chad's ZL1 is offline   Reply With Quote
