Old 10-18-2016, 05:15 PM   #1
cc-rider
Drives: 2010 Camaro SS
Let's talk lifters
Been doing some researching on lifters. What is the consensus around here with the LS forced induction community on lifters? What's a good lifter for the blown LS3?
Been doing some reading and the LS7 and CTSV lifters come up a lot. Then Comp and Johnson. Then you get into the expensive linked lifters. From what I've read so far...seems that the Johnson slow leakdown lifters are some quality pieces (part #2110). Called BTR today and they recommended them. Or the Comp drop ins.
What's a good robust lifter for a 600-700 hp range LS3?
cc-rider is offline   Reply With Quote
Old 10-18-2016, 05:55 PM   #2
Unreal
Drives: 2006 Z06
Its kind of hit or miss. LS3=LS7 lifters. I run stock ls7 lifters in my car, zero issues. Johnson and others were not out at the time, and the 3 high end shops I spoke to all recommended stock lifters.
Morels are nice but $700+. The .750" wheel is a nice upgrade, but you pay for it. If I had to do lifters today, I would do the Johnson ones.
Nick
Corvette Z06 -1200ish rwhp
Old 10-18-2016, 06:07 PM   #3
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
Im running Johnson link bar...after i spun a ls3 lifter...
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 10-18-2016, 08:10 PM   #4
jamesr
jamesr's Avatar
Drives: 2012 Camaro ss
I have the Morels in mine
jamesr is offline   Reply With Quote
Old 10-18-2016, 08:16 PM   #5
cc-rider
Can you tell which Morel part # you have? So many options here. Just want to make sure I research the right ones.
Old 10-18-2016, 11:52 PM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I have Morel 5206s.
Old 10-19-2016, 12:18 AM   #7
Bo White
Bo White's Avatar
Stock LS3/LS7
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 10-19-2016, 07:26 AM   #8
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
LS7 lifters here
MODS:
Old 10-19-2016, 10:21 AM   #9
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
johnson link bar lifters twin turbo setup 23 lbs boost still going strong
1fast is offline   Reply With Quote
Old 10-19-2016, 12:48 PM   #10
Unreal
Drives: 2006 Z06
Which ones? I may get some Johnson's but they have axle oiling, short travel or normal.
Nick
Old 10-19-2016, 01:41 PM   #11
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2022 Silverado ZR2
Morel link bar
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 10-19-2016, 02:30 PM   #12
CFD
Drives: 2SS/RS L99 BLACK
I had my share of lifter failures, went with Morel linkbar but took it a step further with solids.
CFD is offline   Reply With Quote
Old 10-19-2016, 03:32 PM   #13
Slowhawk
Drives: 1999 Trans Am
Most of our builds get LS7 lifters. Some spin past 7500rpm and over 1000hp.
We use morel link bars with blocks that don't except lifter trays but even those I'd rather run ls7 if I could. Seen more aftermarket failures than ls7.
Slowhawk is offline   Reply With Quote
Old 10-19-2016, 07:24 PM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Morel 5206s here.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
