Old 10-21-2016, 12:50 PM   #1
Zyneris
Drives: Black 2012 LT
Timing Chain needs possible service (complicated situation)
I have a 2012 LT.
My check engine like came on about 2 weeks ago. I took it to a local shop that I trust to look at it. He found no issues other than it said that my car was running "Lean" and that I should have my timing chain looked at by a dealer.
No big deal.
However, I purchased an extended warranty when I bought my car and so my warranty is covered by Ford. As per them, it has to be seen a Ford dealer. So I called my local Ford dealer and the supervisor was VERY hesitant about having anyone in his shop look at my car.
I'm very nervous now and am not sure if I should just forego the warranty and take it to a Chevy dealer or if I should go ahead and have the Ford mechanics look at it.
Could anyone advise on the best course of action. I want the best possible service for my car.
Zyneris is offline   Reply With Quote
Old 10-21-2016, 01:35 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
If you bought your warranty through a FORD dealership and is required through a FORD dealership then it is their requirement to service your car. Regardless of the supervisors feelings you have a signed document requiring a FORD dealership to service your vehicle.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 10-21-2016, 08:38 PM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
I bet they were all to eager for you to buy the warranty. Remind them of that
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
dealer, timing chain, warranty
