Old 10-24-2016, 06:53 AM   #1
Rbriska
Drives: 2010 Chevy Camaro 2LT V6
Remote start not working No CEL
Hey guys I got a 2010 camaro 2lt. The remote start stopped working. The lights flash and I hear a click from under the hood. The remote start is enabled in the config menu. There is no CEL's and all doors / hood / truck are closed. Please help thank you
Rbriska is offline   Reply With Quote
Old 10-24-2016, 10:35 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you are not in Park, or the ECM doesn't think you are in Park, remote start will not work.
If you accelerator pedal is not at zero, same thing.
Rock-It Man is offline   Reply With Quote
Old 10-24-2016, 03:21 PM   #3
Rbriska
I'm in park, gear selector says p. Gas pedal is at zero as far as I can tell (not idling high) and break pedal is at zero (no brake lights on). I tried reclosing the hood and trunk and lid but that didn't work. Please any other suggestions? Thanks
Old 10-24-2016, 03:36 PM   #4
Rock-It Man
Assuming your fob is otherwise working, I don't have any other ideas. Either see the dealer or just give up on remote start.
Afterthought: do you have a tune or some gadget that re-maps your accelerator pedal?
Old 10-24-2016, 03:40 PM   #5
Rbriska
No tune or anything... I just installed a CAI a couple weeks ago from Vararam
Old 11-08-2016, 05:16 PM   #6
Rbriska
Bump anyone have any ideas? It worked the other day when the temps increased and it was 80° out. Now that the temps have dropped again still won't work. Iam baffeled.
Old 11-09-2016, 12:22 AM   #7
Foundryrat
Drives: 2014 camaro convertible rs
check the hood switch
have a 15 Silverado animal chewed the wiring to the hood latch switch
Foundryrat is offline   Reply With Quote
Old 11-10-2016, 05:49 PM   #8
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
You need access to GDS2 and look at the Remote Start Disable History. That will tell you exactly what is going on. Otherwise you are just shooting blindly.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
remote, start
