Old 10-26-2016, 05:32 PM   #1
Dhaliwal559
Dhaliwal559's Avatar
Drives: 2015 Chevy Camaro 1LT/RS
Which tires do you guys reccomend for my 2105 1LT RS auto?
Hey guys, I was fine before. Would lose a little traction and go and it was fine. But I switched to a dyno tune and got rid of 89 pounds subs.. now if I try to launch at 1500 RPM or higher, it's a smoke show. My current tires are nitto nt555 g2 315/35/20. Keep in mind, I need tires I can daily with and races on side. Please check out my YouTube video so you can see,
https://youtu.be/N8zm_jZPMjA
Have a good day!
Dhaliwal559 is offline   Reply With Quote
Old 10-26-2016, 06:08 PM   #2
Kenny Camaro
Drives: 2013 1LT RS Camaro
What was the numbers on the dyno tune compared to the overkill tune? Those nittos are a harder compound, you might want to try a softer summer performance tire. Just go with a softer, sticker compound. I know the stock Pirellis are softer than those nittos.
Kenny Camaro is offline   Reply With Quote
Old 10-26-2016, 07:06 PM   #3
Backtoblack1LE
Backtoblack1LE's Avatar
Drives: 2015 SS 1LE
Stabbing the throttle like that doesn't work. Guys with stock tires, and 100+ your torque have cut 1.8 60FT. It may not be the tire..
Backtoblack1LE is offline   Reply With Quote
Old 10-26-2016, 10:30 PM   #4
Dhaliwal559
Just 21 HP and 24 torque
Have a good day!
Old 10-27-2016, 06:08 AM   #5
derek1387
Drives: 2015 1LS Red V6
You should probably post this in the tire and wheel section.
But Kenny is right, the 555's are pretty hard. Decent tire, but dont have crap for grip.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 10-27-2016, 05:13 PM   #6
Kenny Camaro
Was that the overkill or the dyno? On E-85? What was rwhp comparison OK to Dyno?
Old 10-28-2016, 01:34 AM   #7
Dhaliwal559
Overkill- 261 264
Dyno- 283 274
Have a good day!
Old 10-28-2016, 02:55 AM   #8
Kenny Camaro
Overkill- 261 264
Dyno- 283 274
Thanks Dhaliwal !
burnout, nitto, tires
