Old 10-28-2016, 07:52 PM   #1
VINNY1980
VINNY1980's Avatar
Drives: 2010 camaro 2ss abm m6 , 2013 zl1
Send a message via AIM to VINNY1980
10.50-11
What needs to be done to run 10.50-11 seconds 1/4 mile?i have 13 zl1 manual. Has a cai and that's it.
VINNY1980 is offline   Reply With Quote
Old 10-28-2016, 08:38 PM   #2
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
BTR stage 3 cam, 9.1 lower & 2.5 upper pulleys, ID 850 injectors, NW 102 throttle body, AFCO Heat exchanger, LT headers, Roto Fab CAI, and few more miscellaneous parts.
With the list of MODs, I have gone 10.94 & 10.84 on 18" replica wheels with drag radials.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 10-28-2016, 09:32 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
All the mods that Ron listed, but the most important one is a driver mod with an M6
And a drag radial setup, NT05Rs on stock 20" isn't going to cut it either.
Can'tHave2MuchHP is offline   Reply With Quote
Old 10-28-2016, 09:35 PM   #4
Ron_Robinson1
True story brother.
Old 10-28-2016, 09:36 PM   #5
Can'tHave2MuchHP
Drives: Fast
Check out this video...
Owner is a Forum member, I'm sure he'll step in soon. His launch and shifts are a thing of beauty.
Old 10-28-2016, 09:56 PM   #6
Ron_Robinson1
Yeah his name is Chett, fastest M6 ZL1. He can drive...
Old 10-29-2016, 10:35 AM   #7
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Thanks Guys. I hit my first 10.9's @ 683hp/647tq with pretty much the mods the Ron has above on upper pulley. MPH around 128-129 on a 1.62 sixty'. I think that is pretty much the norm to run a 10 in 6M
Add more hp and better tire and you will start to dip from there. Lots of practice also which I still need. The weight of our cars really shows up in a manual. Very fun when it works out though.
Good luck and Have fun with it Man!!
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 10-31-2016, 08:46 AM   #8
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
What I have is in my signature. You do not need a heat exchanger or throttle body, in my opinion. There is definitely controversy on that. I am a convertible so I would be 10.5-6 easy if I was a coupe. I would expect if you shift perfect what I have in a M6 coupe would be a 10.6-7
I spent 7k for the engine mods and then cost of wheels/tires
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
robrocketanski is offline   Reply With Quote
Old 11-01-2016, 12:49 AM   #9
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado
I ran a 10.2@136.
700rwhp/693rwtq
I also have an A6.
ZL W0N is offline   Reply With Quote
Old 11-01-2016, 05:13 PM   #10
Dutchman427
Drives: 2012 ZL1 #1329 M6
Seat Time and the right set-up
Dutchman427 is offline   Reply With Quote
Old 11-01-2016, 05:53 PM   #11
VINNY1980
VINNY1980's Avatar
Thanks everyone. I planned on doing cam swap , exhaust, pulleys , and tune.
Old 11-01-2016, 07:21 PM   #12
Ron_Robinson1
And a good drag radial.
Old 11-01-2016, 08:38 PM   #13
Harley01
Drives: 2015 Camaro ZL1 (red hot)
Money and Time!!!!!
My Mods:
Roto-Fab Intake, Elite Catch Can, ATI Super Damper & 28% OD Pulley, LF Idler pulley bracket, ID850 Injectors, 2" Kooks LT coated headers w/orp, BTR Stage 3 cam, Mild to Wild exhaust controller, TR71X Spark Plugs w/socks, JMS Fuel Pump Booster, LS3 Throttle Body, Alky Meth injection, Ron Davis HX, Roto Fab Reservoir, BMR 1.4" Lowering Springs, Side Vents, Rock guards, Custom painted splitter, rockers and rear fascia, MGW Short Throw Shifter, ZL1 DRL lighting harness, Aeroforce Scan gauges, Car Lock security system, Tuned by JDP Motor Sports, Dyno Tuned (702 RWHP).
Harley01 is offline   Reply With Quote
