Old 10-29-2016, 03:51 PM   #1
Therealbigrich
Therealbigrich's Avatar
Drives: 2020 1SS
Does every Chevy Dealer charger a diagnostic
I know I needed at least my front break pads changes and maybe my back so I decided to go to my closest Chevrolet dealer to get them done since I trust them the most . I was expecting maybe 200 for the front at most and was kind of shocked when he said 280 after taxes for just the front. It was 60 in parts and 250 in labor that was 117 in actual labor and 135 in diagnostic . Is this every Chevrolet dealer that charges a diagnostic even when I say what the problem is or just my bad luck?
Therealbigrich is offline   Reply With Quote
Old 10-29-2016, 04:14 PM   #2
Welker2
Ret AF, cancer survivor
Welker2's Avatar
I believe most if not all do have a 'diagnostic' charge; I know mine does. However, it is supposed to be deducted/voided if they actually do the repair/maintenance' If you choose not to have them do the work, then they will charge the fee ... basically, they're not going to spend their time tracking down/confirming what needs to be done for free so that you can take it home and do the repair yourself or take it somewhere else.
Old 10-29-2016, 04:24 PM   #3
Therealbigrich
Drives: 2020 1SS
Thats what I thought they usually do . He said they had a special going on for 250 I just don't get it . TBH I think I need to find a shop with high ratings cause dealers are getting crazy
Old 10-29-2016, 05:29 PM   #4
audiowhiz
audiowhiz's Avatar
Drives: 2005 Corvette M6
I took mine in to discuss with them the crack or separation in my dash at the air bag. Something notorious in 2010 cars. They claimed they had never heard of it, and that they would charge a $ 90 diagnostic fee to have a tech look at the crack and give an estimate of what it would take to change the dash.
I drove off.
audiowhiz is offline   Reply With Quote
Old 10-29-2016, 07:54 PM   #5
sdynak
Drives: 2014 ZL1
Did they quote on OEM pads? They are about $150 for OEM front SS pads.. Check them out.. https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
I would not use aftermarket.. I'm not going to get into a debate myself .. too many threads doing the same.
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 10-29-2016, 08:05 PM   #6
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
The front brake swap is literally a 30 minute job, also sounds like they didn't go back with OEM Brembos. My dealer tried to give me duralasts(lol) so I went ahead and got Brembo pads from Amazon.
It's the easiest brakes to work on out of any car I've ever worked on
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
NC_SS is offline   Reply With Quote
Old 10-29-2016, 08:06 PM   #7
NC_SS
NC_SS's Avatar
Also to answer your specific question, if I come in and ask for them to check something for me they usually do it free of charge
Old 10-29-2016, 08:21 PM   #8
Therealbigrich
Drives: 2020 1SS
Sounds like I got screwed all over. They had duralast pads as the replacement. Smh I didn't even think about it and it's the winter so I didn't want to do it myself
Old 10-29-2016, 08:23 PM   #9
sdynak
Drives: 2014 ZL1
Ah.. it's not that bad.. you got brakes you needed done.. it will be safe and not cause you any issue under normal driving.. Just costly for what you got but it is done.. Time to open a beer and enjoy the weekend..
Old 10-29-2016, 09:41 PM   #10
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Yep, brake pad replacement on this car is the simplest I've ever done. :P
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 10-29-2016, 09:43 PM   #11
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
You should probably do a small bleed on them too. You can do it with the wheel on if youre flexible.
I've been quoted just under 500 to change the fronts + resurface. I decided to buy the OEM pads for around 200 and do the labor myself. Resurface was 70 at a tire shop.
As for the diagnostic... I think for cars under warranty its free
Soybeanrice is offline   Reply With Quote
Old 10-29-2016, 09:47 PM   #12
jd10013
Drives: 2012 camaro
never understood why people take their car back to the dealership for not warranty/recall work. you know your going to get hosed.
jd10013 is offline   Reply With Quote
Old 10-29-2016, 09:56 PM   #13
jrhagen
Banned
Drives: Camaro
I bought some AC Delco replacement pads at Autozone for around $50 and changed them in my garage in about 30 minutes. I had to lose the roller skates to fit my 17" Welds.
jrhagen is offline   Reply With Quote
Old 10-30-2016, 03:07 AM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you have to ask for OEM parts. I worked at a ford dealer. the customers just assumed they were getting oem when they were really getting cheap carquest at a huge markup.
JCunningham is offline   Reply With Quote
