![]() Drives: 2012 SS Join Date: Feb 2016
GM ASA cam
A friend of mine is giving me a good deal on a GM ASA cam. Is there anyone using this cam? I would like to hear thoughts. The specs are 226/236 .525/.525 110 lsa. I kind of wish it was on an 112 lsa. My car is a m6 with 3.91 gears & will have long tubes on it before the cam is installed. It also is my daily driver. Thanks in advance.
![]() Drives: 2015 SS 1LE Join Date: Aug 2016
Don't. Go get a better sized cam with 3.91. You'll net 30 more RWHP and better sound in the aftermarket.
Are you saying larger?
old school chevy rodder
The cam is spec-ed out to be easy on the stock drivetrain and circle track ASA racing friendly being for a class of stock car for racing..the Camaro/Corvette ls3 Our stock cam has a lot of LSA and lower duration so this cam can make a car sound cammed and will give it more power yet still there are better cams and even with it I would recommend upgrading springs...etc. Most likely to have that cam are aftermarket installs of crate ls3.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Someone with a 1LE installed the Howard's Cams version of the ASA or Hot Cam from GM and put down some very very respectable numbers.
Edit: dyno sheet of that cam in a 1LE http://www.camaro5.com/forums/showpo...0&postcount=10
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Cam has a great torque curve. I take the 1LE results as exception more than the rule.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#7 |
While I realize that there are better cams out there, this deal is hard to pass up. Cam, upgraded springs, pushrods, timing set, hv oil pump $200. I have a good friend that seems to find me some deals.
#8 |
well you know the numbers the stock rated engine comes in crate form with the hot cam doing 480 hp compared to 426 and the ASA doing 525....... sure not exactly the numbers of other high lifts, but with easier on the valve train life and a common option for upgrading say: older corvettes, older Camaros etc....... I know my tuner Tommy Wong has installed several of these up in Vancouver at Wongs performance engineering.
#9 |
![]() Drives: 2011 Camaro SS Join Date: Dec 2010
I just finished building an ls2 with the asa cam. The engine was a 4.005 bore 3.622 stroke, 11:1 compression, cathedral port heads 243, factory rockers/springs, and fast intake. The engine made 547hp with a conservative tune. The engine is designed for road racing application. Hope this helps.
#10 |
I installed the Howards Cams version of the ASA cam and couldn't be happier.
You saw my dyno sheet. This cam is easy on the valvetrain, makes great power and even sound nice. This with headers, hi flows and a great dyno-tune made my 1LE what it should have been from the factory. Like a different car. A couple other guys on this forum followed in my footsteps and they too are thrilled.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
#11 |
![]() Drives: 2015 SS/RS 1LE Join Date: Dec 2014
I want to install a cam myself this winter(Jan/Feb) My 1le is a DD/365. I have to have OEM reliability/longevity, once it is installed I never want to have to maintain the valve train or worry about it. I don't drag race, not worried about 1st/2nd gear, I spend most of my time in 3rd/4th tearing the freeway/interstate up. I was looking at the ASA cam for this reason, is this Howards cam the next best option? What is different between the two? Better power under the curve or just better peak numbers?
To the OP, if you are installing yourself I think it would be worth it to go with the ASA deal, then you would be saving some cash for a little sacrifice in power. If you are having someone install, might as well spend a little extra for the best cam possible. |
#12 | |
I would go with PAC 1218 springs or PSI 1511 springs because of the more aggressive lobes. Blue GM LS6 springs will work but will not control the valves if you rev too high.
2010 2SS/RS
#13 | |
The stock springs work very well with this cam. You are correct though if you want to spin it faster than the stock redline. Not sure why you would though, I left the stock rev limit and you can see on my Dyno Sheet that there is no need to excede it as the power starts to drop off at the top anyways. This cam is a great 2000-6500 rpm choice, the HP levels off at 6000 and the TQ falls off after 6000.
#14 |
Thanks for the info guys, looks like this might be cam.
