Old 10-29-2016, 09:57 PM   #1
vsc85us
vsc85us's Avatar
Drives: 2010 Camaro SS, Metallic Blue, 6spd
Exhaust Removal
Hello,
Has anyone successfully removed a 2010-12 stock Camaro SS exhaust system? I'm trying to replace a parking brake cable but the exhaust system is in the way😑
vsc85us is offline   Reply With Quote
Old 10-30-2016, 01:56 AM   #2
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Lots of people have. It comes out in one big piece from mid-pipe back.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 10-30-2016, 11:11 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
4 jack stands, get car as high as possible(unless you got a lift) loosen both slip clamps(no need to remove!) and push toward engine...need two peeps lower at disconnect point and pull entire exhaust forward and down carefully.....once down pull entire system out the back.....install is reverse but make sure to push exhaust up as high as possible before tightening clamps to it make sure it doesn't hit cross brace...peace out...plus lots of other writes ups on the forum...
btw-wat was wrong with cable requiring replacement?
Old 10-30-2016, 06:49 PM   #4
mpsgolf
mpsgolf's Avatar
Drives: 2012 Camaro SS Transformer
It comes off in one piece from the cats back.
I had to remove the rear diffuser to get the exhaust off the rubber hangars.
The clamp at the cat has two spring tangs that need to be released before the exhaust can slide out.
The only thing holding it in is the clamp at each cat and the rubber hangars, two on each side.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers
Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms
mpsgolf is offline   Reply With Quote
Old 04-28-2020, 06:38 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Okay- sorry to necro an old thread. I’m trying to get my ARH system off and it’s giving me fits. I have both hangers on each side in back off and clamps off the headers and midpipes and cant get any movement on it. Any tips?
joshnmn is offline   Reply With Quote
Old 04-28-2020, 09:35 PM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
Got it out. No worries
