Old 10-29-2016, 09:23 PM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Steam Release
Is there any reason to run one of these steam release kits.
http://www.motionraceworks.com/store...verPeacemaker2
Orange Krush II
Old 10-29-2016, 09:40 PM   #2
camaro34
camaro34's Avatar
Drives: 2011 Camaro SS
If your racing the car for long periods of time the help keep the coolant temp about 10 degrees lower. Otherwise they are not necessary. We use a similar kit on the K&N series LS engines.
camaro34 is offline   Reply With Quote
Old 10-30-2016, 06:48 AM   #3
Unreal
Drives: 2006 Z06
Can buy a $30 oem rear steam vent and a few bucks in hose and do it cheap if you want. Some factory trucks had the rears vented.
Nick
Corvette Z06 -1200ish rwhp
