11-01-2016, 11:24 AM | #1 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Hoping these will solve my low powerband...
As you recall I have been to the dyno 3 times previously... each time making progress, but trying to resolve issues. I run 93 octane and 100% meth.
Car has heads/cam (in N/A form peak power was at 6200-6300rpm). Car now has Huron Seed Single Turbo kit with PTE 7675 with 3" DP into dual 2.5" exhaust. Dyno sessions: 1st time - burnt plug wire but made (8-10psi) 608rwhp/571rwtq and making peak power between 5800-6000rpm 2nd time - burnt three plug wires but made (655rwhp/725rwtq) with boost falling off from 15psi to 11psi and making peak power @ between 5200-5600rpm (flat spot) 3rd time - car ran great but made (703rwhp/762rwtq) with boost falling off from 16psi to 12psi and making peakpower again between 5200-5600rpm In my mind, there is a restriction, so i have done two things: 1) removed the 5.5 long conical air filter. 2) Added electric cutouts As far as #1, I know it helped as my street logs show less boost falling off up top. What does everyone think about the cutouts... I couldnt find a spot for them on the downpipe due to the WB O2 location, so they are on the peipes where the old bullet mufflers used to be (currently connects the the Huron Speed Y-pipe). What kind of gains you think i would see with these two mods? |
11-01-2016, 11:55 AM | #2 |
Drives: 2014 SS 1LE Join Date: Apr 2014
I'm interested in the results.
11-01-2016, 11:56 AM | #3 |
Drives: T Join Date: Mar 2015
i use the same turbo, same kit. I planned on putting a single 3" cutout right at the end of the first downpipe pipe after the turbo. I got lazy and just decided to dump it right there under the front of the driver seat with a turn down, Boost comes on IMMEDIATELY. Running cutouts that far back i dont think will yield that great of a gain its still going through a neck down 2.5".
What plug wires did you end up using? After a few trials with custom plug wires, and stock plug wires i ended up following what was recommended and bought the PCM of NC wires and they fit perfect. |
11-01-2016, 02:20 PM | #4 | |
Oh, and taylor 10.4mm wires with 45 degree boots. |
11-01-2016, 03:49 PM | #5 | |
Too much is never enough!
11-01-2016, 07:57 PM | #6 |
I think I resolved a lot of the boost issue by ditching the filter. A good sign of restriction is when these motors make more tq than hp... Not to mention peak power being so low (which nets less power than tq).
11-02-2016, 11:37 AM | #7 |
Drives: 14 1le turbo Join Date: Oct 2015
I think this kit around 700 needs a cutout to not kill topend. I plan on doing one on the dp right next to the rear of the engine. I plan on having a built shortblock by spring I'm hoping to get around 900rwhp.
2014 1LE 2SS/RS
Huron Speed turbo kit |
11-02-2016, 11:47 AM | #8 | |
I think 900rwhp is gonna be tough to hit with a 7675. You plan on using a 88mm? Here are the installed pics. I still need to mount and wire the switch within the cockpit. |
11-02-2016, 09:26 PM | #9 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
The 76/75 made 900rw on my little 4.6. The trouble with it is the exhaust turbine chokes it and creates to much back pressure. You might be getting valve float.
11-02-2016, 10:04 PM | #10 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Cutouts look good and will certainly help along with not running a filter as well. At the end of the day the 3" downpipe is the bottle neck. 3" can only move x amount of air no matter how big a turbo is before it or how free flowing the exhaust is after it. Think of the guys with twins or SC guys running long tube headers most are working with two 3" collectors abilty to move twice the amount of exhaust flow
Curious to see results for reference I just made 816 on 15psi but waste gate is dumped to atmosphere, which IMO is another big problem being recirculated in an already small downpipe.
11-02-2016, 11:45 PM | #11 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
I am considering putting in a single 4" exhaust connected directly from my downpipe around where the O2 bung exists and running it straight to the rear axle before branching off to two x 3 inch pipes for exit. I wonder if that would be just as good as a cutout without all the weight of cutouts and dual exhaust?
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
11-03-2016, 07:53 AM | #12 |
I hope it isn't valve float... But something to check. Advanced Inductions set up the heads knowing it was going on a boosted vehicle, so hopefully there is some safety factor built into the installed height/seat pressure.
11-03-2016, 09:11 AM | #13 |
Guys tap a pressure gauge to check if back pressure is excessive, I've seen it done both pre and post turbine
11-03-2016, 09:24 AM | #14 |
