Finally dyno'd my car after LSA conversion
Posted in the 1LE forum but figured this would be more appropriate. It's a 2015 1SS 1LE with TSP 2" primary LT headers through dual 3" exhaust with no cats going Into dual flowmaster outlaw mufflers. Sounds insane. Other mods are ADM LSA conversion. With 2.75 pulley, btr stage 1 pd blower cam, ADM cai with race scoop, rear suspension complete bmn except for lca's , adm fpcm, 65lb injectors. Dyno'd 640/578 with the injectors at 86% duty cycle. Debating if I should get ID850'S or a boost a pump. Very happy with the combo. ADM kit was 100% complete and really well done. Definitely recommend ADM kit for anyone thinking of going pd. In hindsight I probably should have went with 85 lb injectors I just didn't think I would have made as much as 640. I figured I'd be closer to 580. Opinions on injectors with my combo ?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Stock fuel pump? Maybe a ZL1 fuel pump swap before larger injectors...
![]() Drives: IOM 2SS/RS Join Date: Dec 2011
10-4....
'It's an experiment'
1LE's eat this kit up. Excellent numbers for sure. Unless you intended to WOT all the time, 80% duty is what you want to be at max duty cycle -- as a safe margin. 86% is close. Are you going for more hp? 850s would be safe and give you room. Those would drop right in. Retune would be necessary.
Every car is different. Your combo breaths well and the hp shows that! How much boost? 9 PSI? Congrats! -Don
747 RWHP 794 RWTQ
#6 | |
#7 |
Ted recommended bigger injectors to get the duty cycle down and give more room for the other pulley and Andy from ADM recommended a boost a pump.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I'd go with better pumps and 85Lb injectors. Your probably running out of pump too
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#9 |
With the adm fpcm and zl1 pump the pressure stayed above 60 even at 6900. Not sure if much more is desirable. In the above picture the fuel pressure is in pink. After Ted was done tuning everything the pressure was relatively consistent at 60 or slightly above throughout.
#10 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
A fuel pump voltage booster won't change that nor will it change the IDC. I am still going to push you toward the ID-850s Your IDC will be around 50 % and leave room for that 2.5 pulley. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#11 | |
I'm probably going to make that my upgrades for next season. I'm just worried about the stock bottom end and unsure how much more power it will take (assuming I get the injector issue in line). |
#12 | |
I am comfortable at 650-670 on your combo on 93 octane but not with your current injectors. Ted.
#13 |
Alright thanks for the info appreciate it !
#14 |
Any time Friend.
Thank you for your business. Ted.
