Old 11-04-2016, 07:38 PM   #1
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Installed CAI on 2011 2LT and Stabilitrack light is on
I disconnected the negative battery terminal in the trunk per instructions prior to installation. However, as the title says - the stabilitrack light is on and will not go off. But SH*T!! the car responds so much better and is an animal now! No hesitation at all! I do recall when installing my VMAX TB I had a similar issue and it resolved itself after a few key turns. However, I've been doing this all day riding around town and the check engine light and the warning indicators are still on. Is there a way to reset it?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 11-04-2016, 07:58 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
OBDII scanner will clear the code.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 11-04-2016, 09:04 PM   #3
SummitWhite11
Drives: 2010 2LT/RS
Thanks!
2010 2LT/RS
Old 11-05-2016, 03:17 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
After hooking up the OBD II scanner and cleared the codes. I still have two codes showing.
P0113 for Intake Air Temperature Sensor Circuit High Input
P0100 Mass or Volume Air Flow Circuit
I also continue to show warning indicator lights for TC, Skid OFF and Skid ON along with the Service Stabilitrak light.
After trying to clear the codes several times they keep returning. Is there another solution?
2010 2LT/RS
Old 11-05-2016, 05:03 PM   #5
Leo72793
Drives: 2011 2SS/RS
Shut car OFF. wait 30 seconds. unplug MAF and plug firmly back in. Wait 30 seconds. start it up. should clear itself. happened to me on my 2010
Leo72793 is offline   Reply With Quote
Old 11-05-2016, 09:44 PM   #6
SummitWhite11
Drives: 2010 2LT/RS
Thanks. It worked out great! However the Engine light still remains on. I suppose this will go away after driving for a bit and the computer will relearn itself? Unless I need to check for code?
2010 2LT/RS
Old 11-06-2016, 04:38 AM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
The reason for better "animal" like characteristics, is the car is relearning everything. Once that learning period is over, it will stabilize back to normal.
Old 11-06-2016, 07:51 AM   #8
Leo72793
Drives: 2011 2SS/RS
Pull the code. Make sure your MAF isn't backwards in the intake pipe. Otherwise its read wrong.
Old 11-06-2016, 07:38 PM   #9
SummitWhite11
Drives: 2010 2LT/RS
Ok I pulled the code and it showed a P0100 for the MAF. I had the code erased and now the engine light is no longer showing. I drove it for the day and it seems to be fine. If the light returns then I'll know it's the MAF and I will need to turn it around. However, I'm pretty sure I installed it correctly. Thanks for the help!
2010 2LT/RS
Old 11-06-2016, 08:26 PM   #10
Leo72793
Drives: 2011 2SS/RS
theres an arrow on it. check it when you can. it can takes up to 50 miles or 5 cycles to pop a code
Old 11-07-2016, 04:55 AM   #11
rtcat600man
If I remember correctly you can not install the MAF backwards, due to the shape of the housing.
Old 11-07-2016, 06:42 PM   #12
SummitWhite11
Drives: 2010 2LT/RS
Exactly my thoughts since I was pretty sure I put it in the correct way. So far the engine light has not returned and no codes are coming up on Day 2 now.
2010 2LT/RS
Old 11-08-2016, 12:59 PM   #13
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Thanks for purchasing the Cold Air Inductions, Inc. system. We are glad that you are having no issues and that you can feel the performance gains. Thanks again.
Sales @ CAI Inc is offline   Reply With Quote
Old 11-08-2016, 06:50 PM   #14
SummitWhite11
Drives: 2010 2LT/RS
2010 2LT/RS
