Old 11-07-2016, 06:47 PM   #1
littlefielc
Drives: 2013 convertible Hot Wheels
Eliminate power draw on accessory
I need to put the switch in accessory to unlock the steering for flat towing. I'm trying to figure out which fuses to pull in order to eliminate the power draw. I don't think there's anything in the engine compartment that needs to be pulled. In the instrument fuse panel there's one called 'battery' that may do the whole thing. Also, 'cluster', 'display', and 'steering wheel controls backlight'.Not sure about 'discrete logic ignition switch' or 'diagnostic link connector' .
Anybody have an idea what it takes to eliminate the power users on accessory?
littlefielc is offline   Reply With Quote
Old 11-07-2016, 07:48 PM   #2
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Not sure which fuse but if all else fails disconnect the battery.
Talladega is offline   Reply With Quote
