Old 11-10-2016, 10:25 PM   #1
8balldeluxe
Drives: 2010 Camaro SS Victory Red
P0523 code
Ok I got this code this evening, P0523 seems to be reading high oil pressure, but the gauge reads a big 0, any thoughts? I got no warnings that came up about low oil pressure. All help appreciated
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 11-11-2016, 08:00 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
I would have it towed to a dealer and have them look into it . I wouldn't driving it unless you want to create a paper weight . Hopefully you haven't damaged the engine already. And hopefully its just a bad sensor .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 11-11-2016, 09:15 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
The oil pressure sending unit is a little a pain to replace behind the engine next to the firewall, a recent replacement by another member on this forum in a thread shows good useful info to start with, as I would replace that then worry about the oil pump....as high oil pressure a ? most likely bad sensor.
Old 11-11-2016, 09:28 AM   #4
8balldeluxe
The CEL came on 2 blocks from home and dropped oil pressure, I coasted into the driveway and pushed into the garage. I did not have any warnings appear on the DIC, I heard no knocking or lifters. Hopefully just a sensor.
Old 11-11-2016, 09:33 AM   #5
christianchevell
Here you go bud, good luck.
http://www.camaro5.com/forums/showthread.php?t=468929
Old 11-11-2016, 09:59 AM   #6
8balldeluxe
Well shit I did a search and didn't find this
Old 11-11-2016, 10:29 AM   #7
1Coopgt
1Coopgt's Avatar
Fingers crossed for ya . At least you were close to home .
Old 11-11-2016, 04:03 PM   #8
8balldeluxe
Just the sensor, thank you to the above info as well as the original poster of that thread
Old 11-11-2016, 04:08 PM   #9
8balldeluxe
I was counting my pennies last night for a new cam upgrade, guess I'll keep saving
Old 11-12-2016, 09:49 AM   #10
christianchevell
And there you go!
Old 09-19-2024, 12:14 AM   #11
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Same came here last tuesday and is still on.
- Oil pressure warning light on the instrument panel did not come on when the engine was running.
- I stopped and looked at the oil, ok.
- No extra noise.
- I drove 12 mi home carefully and looked at the log.Driven normally since then.
Oil pressure send unit will be changed next tuesday.
Btw.Which sensor triggers the oil pressure warning light on the instrument panel ?
Old 09-24-2024, 09:17 AM   #12
chevy pilot
Problem solved.
Old 09-24-2024, 06:29 PM   #13
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
FYI on this code - The description of this code is Engine Oil Pressure Sensor Circuit High Voltage. This code sets when the PCM sees an open/High resistance or a short to voltage. The way I test this is to disconnect the sensor connector and with the ignition on test the gray wire for 5 volts, Black wire for ground and the Tan/White wire for less than 4.8 volts. A poor ground on the Black wire will cause a high signal voltage on the Tan/White wire. The Engine Control Module provides ground to the oil pressure sensor. In most circumstances the oil pressure sensor has failed and is the fix. I highly recommend if your gonna do your own diagnostics/testing to get a power probe and learn how to use it properly. you can do some damage to components/circuits if you dont know how to use it.
Mouse330 is offline   Reply With Quote
