Old 11-14-2016, 08:17 PM   #1
Frostbite13
Frostbite13's Avatar
Drives: '13 2ls
Smile Hp question?
Hi everyone currently my 2013 2ls a6 has kanN cold air intake and a SLP loudmouth one exhaust what else what I need to add more hp and to get the car to the next level I like my 0 to 60 be about 5.5 seconds. I also have a VTC The car is also running on 295's in the rear. Thanks in advance for any feedback.
Frostbite13 is offline   Reply With Quote
Old 11-14-2016, 08:23 PM   #2
Kenny Camaro
Drives: 2013 1LT RS Camaro
Nitrous or changing your rear end gearing.
Kenny Camaro is offline   Reply With Quote
Old 11-14-2016, 08:38 PM   #3
Frostbite13
Drives: '13 2ls
What Gearing do you recommend and how much that would that run me with labor included
Old 11-14-2016, 09:29 PM   #4
ev_santillano
Drives: 2017 1SS Camaro
3.55 are the only option available for the stock rear end I believe. You could swap for a ss rear end and your options really open up. What are the stock 0-60 times on these cars?
ev_santillano is offline   Reply With Quote
Old 11-14-2016, 09:37 PM   #5
Kenny Camaro
3.55 richmond runs about 550, and labor depends on if you pull it and take it in or have them pull it and do it. Depends on who does it but 300-400 if you take he pumpkin in to the garage, probibly double that if you drive it in and have them do it all. SS rend swap opens up all the options ,but costs a lot more.
Old 11-16-2016, 06:09 AM   #6
derek1387
Drives: 2015 1LS Red V6
We cant price out your labor, or what its going to cost you. Different places charge different amounts.
New gears are about $450. Expect at least that, if not more, in labor.
Or do what I did and buy a complete rear end and just swap that out on your own.
I went with 3.91's as I was planning on staying NA. Ended up going FI, and now want to go back to 3.27 or 3.45's.
Now, you being a 2LS...you will need a rear end, axles, hubs, and drive shaft.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 11-17-2016, 01:18 AM   #7
Chantro5
Chantro5's Avatar
Drives: 2015 Dodge Challenger R/T Scat Pack
Not to hijack the thread, but would would I need all of that to if I wanted to go 3.91?
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein
Chantro5 is offline   Reply With Quote
Old 11-17-2016, 04:16 AM   #8
Kenny Camaro
Yeah man, and a tuner to change your gear ratio setting in your ecu.
Old 11-17-2016, 06:07 PM   #9
derek1387
Yes. Because you have the 2LS you would need everything. The 2LS has an entirely different carrier, axles, Hubs, etc
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 11-17-2016, 06:45 PM   #10
Kenny Camaro
The 3:55 is the only option for the 2ls. I was checking into the SS swap for my auto LT and depending on options, it was running about 2,000.00 bucks. But with the SS transplant you also get positraction as the SS rear end is a limited slip differential and the automatic differential in the 2ls is an open diff that is only one wheel drive.
Old 11-17-2016, 10:53 PM   #11
ev_santillano
Does the ss rear end (hubs, axels, and all) fit fine in the 2LS? Are there any other extensive modifications needed?
Old 11-18-2016, 03:53 AM   #12
derek1387
Yuppie
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 11-18-2016, 04:09 AM   #13
Kenny Camaro
When you swap into a SS rear end to change the gear ratio, you want to change at least to the to the 3:45, otherwise you won't feel much difference. The standard ratios on the SS are 3.27' 3.45, and 3.91. 3.91 will give you the greatest improvement in acceleration and mechanical torque improvement and lowering your et's in all areas. It will also lower your gas mileage.
Old 11-18-2016, 06:23 AM   #14
chasmanian
chasmanian's Avatar
Drives: 2015 Camaro SS
Jacfab makes an intake spacer that I felt made a huge difference. Easy install too.
chasmanian is offline   Reply With Quote
