Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 11-16-2016, 01:31 PM   #1
Roger Stattel
Drives: 2012 Camaro 1ss
3.91 rear end, drive shaft, 1 axle, spindles
I'm doing the zl1 rear end upgrade, need these gone, so let me know if there's any interest. 3.91 gears in the pumpkin, also have a set of 3.45 in garage. 24k on diff, and 7k on the 3.91 gears. Have drive shaft for auto zl1 also.
Pm me offers.
Roger Stattel is offline   Reply With Quote
Old 11-16-2016, 02:14 PM   #2
NEstyle
Drives: Caprice
PM sent on 3.91 rear.
NEstyle is offline   Reply With Quote
Old 11-16-2016, 09:14 PM   #3
Redbeard 11
Drives: 2011 1SS LS3/ SC
PM SENT ON DRIVESHAFT
2011 1SS LS3/ Eforce 3.25,FC#72,JRE fuel rail mod,V-max PTB.,alky meth, CAI intake, BTR Stage3 cam supp.mods,melling O.P. etc. MSD wires,SW headers and exhaust, fidanza alum.flywheel and ceramic clutch, tick speed bleeder,DSS 1pc. alum.ds., ZL1 3.73 cradle, slotted rotors w/ceramic pads,20" Z28 replicas 650RWHP/635RWTQ
Redbeard 11 is offline   Reply With Quote
Old 11-17-2016, 05:37 PM   #4
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
in for the diff!
JT Camaro is offline   Reply With Quote
Old 11-23-2016, 08:44 PM   #5
Roger Stattel
Update guys, sorry for the delay, have been working a lot.
Still have diff, several ppl have pm'd.
Manual ss drive shaft
Auto zl1 drive shaft
SS Spindles
Zl1 hubs
Driver side ss axel.
Pm for pricing.
Old 11-23-2016, 10:38 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
How much for Z hubs?
Orange Krush II
Old 11-25-2016, 09:54 PM   #7
Roger Stattel
To clarify these are just the hubs, brake shields and what not. No spindle/bearings.
Old 11-26-2016, 03:44 AM   #8
Roger Stattel
For everyone interested in diff, the first buyer has backed out, decided to go a different route. Sorry for the delay, it sounded like things would play out.
Old 11-27-2016, 01:38 PM   #9
Roger Stattel
Bump
Old 11-28-2016, 04:07 PM   #10
ZeroC
ZeroC's Avatar
Drives: 18 2SS LT4 Top
Pm me on the 3.91 I need to replace mine !!!
ZeroC is offline   Reply With Quote
Old 12-03-2016, 11:52 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
PM sent!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 12-06-2016, 06:42 AM   #12
DOC52
THE U
DOC52's Avatar
Drives: Camaro 1SS/RS
Did you ever have the diff opened up and checked out? I really hope you did because deleteing your original post about a possible diff failure and trying to sell it now as a 24k, only 7k on the gears, unabused item is a scumbag thing. How many dry burnouts were done on the diff?
http://www.camaro5.com/forums/showthread.php?t=473314
DOC52 is offline   Reply With Quote
Old 12-06-2016, 08:28 AM   #13
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Wow
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 12-06-2016, 11:57 AM   #14
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
?was there anymore to the thread or just started? to be fair...context is everything....
