Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 11-18-2016, 12:08 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up Stainless Steel Brake Lines @ Phastek Performance
NOW AVAILABLE!!
In-stock and ready to ship!!
FREE SHIPPING @ Phastek Performance!!
Upgrade your factory rubber brake lines to the Performance Brake lines from Phastek Performance. These Performance Brake Lines are made with an inner Teflon hose wrapped in stainless steel armor with an overlying layer of abrasion-resistant plastic. These Performance Brake lines will reduce any brake fade that you might incur during a hard track event or even heavy stop and go traffic by reducing the swelling of the factory rubber brake lines.These stainless steel braided lines use high quality steel fittings to prevent any corrosion and are also DOT compliant, MVSS-106 certified. The lines will fit directly in the factory location using steel hangers with a rubber grommet to prevent any metal to metal contact. These performance brake lines are extremely resistant to impact from road debris when compared to the factory rubber line which is susceptible to cracking or tearing with any road debris contact. These lines are rated in excess of 6000psi where the factory rubber brake lines are rated for 1200psi. The extra resistance that these lines can withstand allow for maximum pedal feel under hard braking or extreme conditions.
Features:
  • Hose construction - Inner teflon hose wrapped in braided stainless steel armor with an overlying layer of abrasion-resistant plastic.
  • End fitting construction - High-quality steel fittings, corrosion-resistant with DOT-compliant collar to protect fitting-to-hose junction.
  • Pressure capability - Tested in excess of 6000PSI
  • DOT compliance - MVSS-106 certified
  • Mounting Attachments- Rubber-grommeted steel mounts that bolt into the factory locations.
  • Protection - Stainless steel braided armor is extremely resistant to impact from rocks and other road debris as well as rubbing wear from suspension components.
  • Lifespan - Essentially lifetime
  • Function - Greater pressure capability means less expansion under pressure, which results in a firmer pedal, better pedal modulation and control, and insignificant change due to elevated temperature levels from track or race use.
  • Made in the USA
Black Lines #5BLBL
Blue Lines #5BLB
Red Lines #5BLR
Sales@Phastek is offline   Reply With Quote
Old 05-12-2017, 02:38 PM   #2
Sales@Phastek
brake lines, phastek performance, stainless steel brake lines, stopping power
