![]() Drives: 2014 2SS/RS 1LE, Supercharged Join Date: Jan 2014
LS9 heads on LS3 block
Good evening from Germany.
After my Kraftwerks supercharge install I´m now looking to exchange my stock LS3 heads for more durable GMPP CNC ported LS9 heads. My challenge is not the fitment - that should be fine. I´m wondering about the head bolts. LS9 needs 12mm head bolts. LS3 block has 11mm. Jegs recommends the standard 11mm GMPP bolts. But there will be obvious a 1mm difference...not sure if this is a sustainable solution... I don´t want to re-tapp the LS3 block for 12mm. Any suggestions from the experts? |
#2 | |
Drives: Anything I want Join Date: Oct 2008
We machined sleeves for our cars when we do this setup. |
![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Dec 2006
Welcome to Camaro5 from Germany! I lived in Düsseldorf from 2011-2014. Good to see some Camaro's running the autobahn's in Deutschland. Wish I was there to enjoy the Christmas markets and have a nice glühwein this time of year.
I looked into these LS9 heads on a LS3 myself. As ADM says...you either need custom sleeves or to machine the block. If you add up all the time and cost in that...there are a lot better options out there for the money. Look into some LSA heads (seen them used for as little as $700) which have a much stronger grade aluminum to them....or even go all out with something like a Trickflow GenX head with a thick deck that can really handle big boost. I suppose if you could get a reputable shop like ADM to machine you some sleeves and find a used pair of LS9 heads...that would be a cheaper option. But heads haven't been proven to deliver huge amounts of power in terms of general flow capabilities. But some of the higher quality heads certainly have allowed for a lot more boost before pushing water which has produced a lot more power. So my advice is think of deck thickness and casting quality first for boost. Hope that helps. Auf Wiedersehen! |
