2010 - 2013 RS Halo Assembly Pictures Wanted
Does anyone have a good picture of the halo headlight assembly? I'm looking into adding a color change option but I don't want to hack it up like the Oracle halo kit. I don't mind baking it open but I don't want to hacksaw the halo. I think there are options out there that do not require the LED ring. Any pictures, help or advise on this would be greatly appreciated. Thanks.
#2 | ||
Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
Maybe this video helps...
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
![]() Drives: 2020 Orange Crush 1SS/1LE Join Date: Jun 2016
http://www.diodedynamics.com/store/c...category/1451/
I have been swapping emails with Steve, and I think this is a great option. I am going other route, as I don't care much for color changing, just a more powerful and dimmable cool white set up. Just take the headlights out, open the bottom access port, carefully unscrew the LED heatsink, and swap the OEM LED, for the RGBW (get the RGBW instead of an RGB... the white, will never be white on RGB, close, but not the same) board. For the price, DD can't be beat on this one unless you build your own set up as I am. |
Maiden69, Thanks man!! This is exactly what I was looking for! I'm going with the DD solution.
#6 |
![]() ![]() ![]() ![]() Drives: 2011 2SS Join Date: Mar 2015
NIGHT OWL!! I did it all myself. Very straightforward. Feel free to pm me with any questions
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
#7 |
![]() Drives: 2021 scatpack challenger 6spd cinna Join Date: Oct 2015
Hi,
Here is a picture of the assembly diagram http://www.wholesalegmpartsonline.co.../92240994.html Thanks, Kevin |
#8 | |
Buckeye
Drives: 2013 2SS RS 1LE Join Date: Apr 2012
NightOwl
Tags |
halo headlights |
