Old 11-19-2016, 01:32 PM   #1
BEECHFRONT
BEECHFRONT's Avatar
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS
Bolt on mod questions
I am looking to do some bolt on mods and have some questions.
I am doing
Cai
10" lower pulley
ID 850 injectors
LT headers/cats
Bap
CC
Hx
IC resevoir
Do I need a tune with these mods?
Is there anything else required to make these bolt on's work?
Thanks.
BEECHFRONT is offline   Reply With Quote
Old 11-19-2016, 01:38 PM   #2
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
Yes, you will need a tune.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 11-19-2016, 01:49 PM   #3
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
I am doing
Cai
10" lower pulley
ID 850 injectors
Thanks.
You are going to need more fuel as well. I was able to get away with a 9.55" but anything over a 9.55" and your going to néed a BAP. With that level of boost, I would probably do headers as well to drop the boost a bit.
The big questions that never seems to get asked is, what do you plan on doing with the car? What are your goals?
crazydave is offline   Reply With Quote
Old 11-19-2016, 01:54 PM   #4
BEECHFRONT
BEECHFRONT's Avatar
Some drag and spirited driving for now
Possibly some track in the future
Old 11-19-2016, 01:58 PM   #5
BEECHFRONT
BEECHFRONT's Avatar
can it safely be driven to get a tune after I install?
Old 11-19-2016, 02:39 PM   #6
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Get a hold of Ted at Jannetty Racing... he can set you up with everything including tune
Crash76 is offline   Reply With Quote
Old 11-19-2016, 03:16 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
No!
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 11-19-2016, 03:46 PM   #8
BEECHFRONT
BEECHFRONT's Avatar
Originally Posted by ZO6 Bryan View Post
No!
Thanks
Old 11-19-2016, 03:58 PM   #9
crazydave
crazydave's Avatar
I am not personally pushing a particular vendor, but Ted does assembe some good combos of parts. Check him out as well as some of the other forum sponsors and see if you can find a package deal. Personally fron your listed goals I wouldn't go any higher than a 9.10 lower to keep some traction on the street and boost temps reasonable.
Old 11-20-2016, 12:16 AM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
99 percent of the time I agree with ZO6bryan, however I think if your only going a few miles, and don't put your foot into it, you will be ok. That being said, he knows a hell of a lot more about ZL1's than I do, and the mods your doing to it.
Best thing I can tell you to do is get a hold of a tuner who can get you a startup file, then do some remote tuning. Or have him get you a startup file so you can drive it into his shop.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 11-20-2016, 08:38 AM   #11
d454brisson
Drives: 2014 ZL1
The ID850s will need a tune to get the flow rates correct, i think it would be super rich and hard to keep from flooding the cats without a base tune for those at least.
When I did my 850s I had a Jannetty tune and it fired and idled right up. I didnt start it with out the tune to see if it would idle.
DB
d454brisson is offline   Reply With Quote
Old 11-20-2016, 08:58 AM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
do not start the car with ID850s without at least a revision in the fuel injector flow table. It will start, but it will be extremely rich as stated above.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-20-2016, 02:55 PM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Yes it will flood out. You can install all the other parts and drive it easily and be allright. But as soon as you put the injectors in it will need tuning to even get it to run.
Bryan 2018 ZL1 M6
Old 11-20-2016, 03:13 PM   #14
BEECHFRONT
BEECHFRONT's Avatar
Thanks for all the advice.
