Old 11-19-2016, 02:20 PM   #1
NeedlessKane
NeedlessKane's Avatar
Drives: 2010 2SS/RS IBM
Just checked my oil catch can - wow
I guess it's better for this oil to be in the can vs being burned but it's scary that so much has accumulated. Last time I emptied it was when I changed my oil, which was around 10k miles ago.
I wish my wife was as dirty as my car....
2010 2SS/RS 6sp
1994 Mazda Miata
NeedlessKane is offline   Reply With Quote
Old 11-19-2016, 02:30 PM   #2
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Holy that is full. Reminds me to check mine now.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-19-2016, 02:30 PM   #3
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Before this opens up Pandora's box and moved to another subforum.
Catch cans are great, they do exactly as advertised ... and that's to prevent / minimize the oil that would otherwise end up in the intake.
How useful they are or whether that's even worth it is another debate that can found here, here, here, here and here*10,000
https://www.google.com/?gws_rd=ssl#q...h+can+worth+it
/thread
Dmpsix is offline   Reply With Quote
Old 11-19-2016, 02:31 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Change your oil more often.
An unmaintained catch can is more dangerous than running without.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 11-19-2016, 02:45 PM   #5
NeedlessKane
I usually check mine every few months but hadn't for whatever reason. I've had it installed for 3 years and this is the first time it's been this full.
2010 2SS/RS 6sp
1994 Mazda Miata
Old 11-19-2016, 05:07 PM   #6
BLU DUCE
BLU DUCE's Avatar
spike III Build IBM 1SS/RS [COTW] 6/25/12
Really 10,000 miles since last oil change?
Old 11-19-2016, 06:04 PM   #7
Kenny Camaro
Drives: 2013 1LT RS Camaro
Change your oil every 3000-5000miles max! Dump you catch can every 1000 miles. Your not supposed to let it get more than 1/3 full.
Kenny Camaro is offline   Reply With Quote
Old 11-19-2016, 06:05 PM   #8
Dmpsix
Dmpsix's Avatar
Idk about 3000, 5000 every few months seems about right.
Every 3000 for non cammed cars seems excessive.
I do it 3-4 times a year no matter what.
Old 11-19-2016, 06:24 PM   #9
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
I change mine every 8k and have always had good reports from Blackstone. Not too sure why people are freaking out about a 10k change.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 11-19-2016, 06:28 PM   #10
NeedlessKane
I change it when the oil life gets to 20-30%. It's a weekend car that doesn't get drive hard. With a synthetic oil, 10k isn't excessive at all.
If the oil was supposed to be changes at 3-5k mile intervals then GM would've programmed their management system to reflect that.
2010 2SS/RS 6sp
1994 Mazda Miata
Old 11-19-2016, 06:30 PM   #11
NeedlessKane
Exactly - especially when it's driven by the OLM. If it hit 20-30% in 3-5k miles is happily change it, but it doesn't.
2010 2SS/RS 6sp
1994 Mazda Miata
Old 11-19-2016, 06:31 PM   #12
NeedlessKane
3-5k is way too often for a car that doesn't get driven hard.
Waste of $$.
2010 2SS/RS 6sp
1994 Mazda Miata
Old 11-19-2016, 06:38 PM   #13
NeedlessKane
I just ordered a Blackstone kit, will report the results when I get them.
2010 2SS/RS 6sp
1994 Mazda Miata
Old 11-19-2016, 06:38 PM   #14
gringo
gringo's Avatar
Drives: Camaro V6
I think you got bigger problems than not just changing the catch can often enough. That much accumulated oil in 10K miles on a non-direct injected engine is NOT good.
gringo is offline   Reply With Quote
