Old 11-20-2016, 11:29 AM   #1
diablo0730
Drives: 2015 Camaro 1LE
What else would be good to grab for my cam install.
So simple question I got a GPI SS3 Cam kit on the way, has the c5r chain, everything basically I would need. My car already has Long Tube Headers and CAI. What else can I get for a reasonable price to squeeze a little more power out of it. Also should I invest in gauges ie wideband etc. or not? Would a full 3 inch exhaust help or not since I'm on factory pipes just straitpiped.
diablo0730 is offline   Reply With Quote
Old 11-20-2016, 12:49 PM   #2
SrtWtF
SrtWtF's Avatar
Drives: Nsrt & Camaro SS
UDP
Gpi rod mod intake
150 shot nitrous
SrtWtF is offline   Reply With Quote
Old 11-20-2016, 02:30 PM   #3
jc615
jc615's Avatar
Drives: Camaro and Sierra
I'd do exhaust, look into a udp as above if you want but don't buy a cheap one. At I, fluidampr, powerbond what I'd look into. It won't gain you much at all but you're already taking it apart.
jc615 is offline   Reply With Quote
Old 11-20-2016, 02:48 PM   #4
dentnshell
dentnshell's Avatar
Drives: Black 2014 2SS
Looks like you are a 2010. There is power to be had in the UDP, especially if you have hydraulic power steering. I did not do it as I had electric power steering. I had Ryan do the rail mod when I did my SS1. Bo White may or may not be porting again, if he is get it while you can! might as well only tune the car once.
Obviously ported heads would be great, but probably outside of the budget.
A 160 Thermostat is debatable at this time, Ryan recommends one.
I highly recommend Ryan tuning the car! He does a great job. I am working on a trip back to Little Rock for a tune after my ADM LSA Conversion. (still have my SS1)
I would also do a catch can at this time if you don't have one... Help keep that new top end clean.
Most suggest a new oil pump at this time.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.)
dentnshell is offline   Reply With Quote
Old 11-20-2016, 02:53 PM   #5
diablo0730
I've been thinking UDP but have been seeing some people saying that it's not really worth it. I was looking into the intake mod as well. As for exhaust I was thinking 3inch into Spintech mufflers if did that. I'll ask the shop doing my cam about a porting my heads. I'm getting the cam installed and tuned for $900.
Old 11-20-2016, 02:58 PM   #6
dentnshell
dentnshell's Avatar
Originally Posted by diablo0730 View Post
I've been thinking king UDP but have been seeing some people saying that it's not really worth it. I was looking into the intake mod as well. As for exhaust I was thinking 3inch into Spintech mufflers if did that. I'll ask the shop doing my cam about a porting my heads. I'm getting the cam installed and tuned for $900.
That is cheap! Un-comfortably cheap.
You will likely see more seat of the pants power out of 3.91 gears vs the pulley.
Same goes for exhaust... If you can go catless you will like gain more power than HF Cats on 3"...
Old 11-20-2016, 03:00 PM   #7
diablo0730
Yea I got a deal because a buddy of mine is friends with the owner haha. So do 3inch exhaust since I'm already straitpiped or leave it as is? And 3.91 gears....I was thinking of doing gears but can never find a shop that installed reasonably. And I've never done gears so I can't do it myself.
Old 11-20-2016, 03:07 PM   #8
dentnshell
dentnshell's Avatar
I would look at the Ported TB and Intake mode - So that you only have to tune once. I think there is more power to be had in the intake side vs the exhaust side.
Look up the Rick Crawford or GPI rail mod - they are the same. Essentially two stainless steel rods that are melted into the back of the intake manifold and bolted on the front.
I sold mine after the LSA Conversion. $300 mod unless you do it yourself. Expensive power compared to the price for your CAM.
Old 11-20-2016, 03:10 PM   #9
dentnshell
dentnshell's Avatar
Here is the thread of my for-sale thread...
http://www.camaro5.com/forums/showthread.php?t=467254
decent pic of the rail mod... would be easy to do for someone with the ability to weld stainless... Again a stainless rod with a nut welded onto it. Then run a bolt through the intake to the nut.
Old 11-20-2016, 03:14 PM   #10
diablo0730
I looked into the GPI mod but don't have my I take off to send it to them yet for the mod. A ported TB would be nice believe there are a few guys selling some Bo white ported ones near me.
Old 11-20-2016, 03:42 PM   #11
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Here is a link For a limited run of Bo White ported TB's.
http://www.camaro5.com/forums/showthread.php?t=472363
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is online now   Reply With Quote
Old 11-21-2016, 02:19 AM   #12
DOC52
THE U
DOC52's Avatar
Drives: Camaro 1SS/RS
New oil pump because you're a manual.
DOC52 is offline   Reply With Quote
Old 11-23-2016, 01:11 PM   #13
diablo0730
Already have a new pump came with the kit.
Old 11-25-2016, 11:57 PM   #14
Skoonie
Drives: 2010 SS M6
Drag radials...
Skoonie is offline   Reply With Quote
cam, engine, power, swap, tune
