Old 11-21-2016, 04:57 PM   #1
kketteridge22
Drives: 2010 Camaro LT V6
How to replace coolant temp sensor
I took my 2010 V6 Camaro in for a coolant change yesterday at a local auto shop. As soon as I got on the freeway going home, I got a check engine light on for engine overheating.
There were no problems before the shop changed the coolant, but they deny all responsibility for any coolant issues. They think it's the sensor because they checked the actual temperature and was not overheating, which points to a bad sensor.
I bought the part online today to replace myself since it's $20, but I'm having trouble locating it. I did see a couple diagrams online, but I still can't find it.
Has anyone changed this part out, or can help me find where it is? the diagram shows it on the driver side, side of the engine. I took some pictures, but need further guidance on where this sensor is.
kketteridge22 is offline   Reply With Quote
Old 11-21-2016, 09:59 PM   #2
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
its to the right of the oil filter ill take a pic
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 11-22-2016, 11:06 PM   #3
kketteridge22
I believe I found it, but not sure how to access it.
I tried getting a 19mm wrench down there and the oil dip stick and some other hoses are in the way.
Is there a step by step for removal?
Also, once removed, will the coolant leak out?
Old 11-22-2016, 11:25 PM   #4
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Gonna probably leak a little. I would check my fuild level again and check for air in the system. Unless the problem was there before you had it serviced. Just a thought. Run the car with radiator cap off for a good 10 minutes and purge the system. Good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 11-23-2016, 10:28 AM   #5
kketteridge22
Does anyone know the steps to access this, or is there a special tool I need? I can't reach it with a regular wrench, too much stuff in the way down there.
Old 11-23-2016, 10:52 AM   #6
CFD
Drives: 2SS/RS L99 BLACK
I have a feeling you should double check coolant level first, it could be coincidence that it failed after being serviced but I wouldn't bet money on it.
CFD is offline   Reply With Quote
Old 11-23-2016, 01:54 PM   #7
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
I was thinking it probably has an air bubble in the system. That it probably wasn't bleed well enough. I agree with you that it would be just to odd for it fail exactly when the flush was done. Not that it couldn't, but so not likely.
Coleroad is offline   Reply With Quote
Old 12-09-2016, 03:19 AM   #8
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
Remove senor plug, then use an extension and a deep socket 19mm to remove. It seems like you can access it without removing anything. Use a swivel adapter if possible to get more access good luck. Btw its the shops responsibility to find out why its overheating . They were the last people to service the car. Dont take your car to a low tier shop a reputable shop would try to fix this simple problem
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 12-09-2016, 10:10 AM   #9
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
This^. Don"t chase parts. It is frustrating and can be expensive. Trouble shoot the simple solutions first, like low coolant level or air trapped in the system. You can check the sensor (or if your not an electrically orientated person), or a shop can check it first to verify if it's bad. I'd say, not likely that the sensor would fail right after your coolant was flushed....Bottom line, if you trust that shop, have them figure it out. Otherwise find another one.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-09-2016, 06:00 PM   #10
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
You probably have air in the system. Highly doubt the sensor is bad
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 11-04-2019, 01:26 PM   #11
Leo155
Drives: 2010 camaro LS
Has anyone found a way to remove the sensor
I tried using a deep socket but the oil stick would be in the way, is there a special tool I don’t know about? The engine light is giving me a code for the sensor
Leo155 is offline   Reply With Quote
