Old 11-22-2016, 02:56 PM   #1
jimitkr
Drives: 2015 Camaro SS With 2SS
Are these rims heavy?
Friends,
Just traded in a 2014 2LS (323 hp) for 2015 2SS (400 hp). Trying to get more and more info on this car ....
I'm adding a photo of my rims here (i think they're stock but not sure). I actually feel these rims causing my beast to decelerate fast, especially <50 mph.
One grasp at the spokes and i know the rims are darn heavy... is it true?
Does anyone know of lighter options?
jimitkr is offline   Reply With Quote
Old 11-22-2016, 02:58 PM   #2
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
Those do look like OEM rims
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 11-22-2016, 03:10 PM   #3
jimitkr
Yeah most probably they are; and they look heavy. Looking to find some lighter options...
Old 11-22-2016, 03:15 PM   #4
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
They weigh around 32lb each, give or take.
14Black1LESS is offline   Reply With Quote
Old 11-22-2016, 06:48 PM   #5
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
There are plenty of wheel options that are lighter than OEM. OEM wheels on most mass-produced cars are made from cast aluminum. Cast is relatively cheap, strong, and they meet federal crash standards. The big disadvantage of cast wheels is they typically weigh a lot. Some rare factory cars come with forged aluminum wheels. The ZL1 and Z/28 have forged wheels from the factory. Forged wheels are strong and very lightweight but they cost MUCH more than cast.
There are many forged aluminum wheel options available but be prepared to bring the $$$.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 11-22-2016, 09:38 PM   #6
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Congratulations on the new ride!
You went from a V6 geared to get 30MPG to a romp-em, stomp-em V8 geared to go fast, stop fast, and corner better than most.
Yes, there is more drag but it is more than the wheels. You have some wide tires, a bit more weight, more drive-line loss from heavier components...
Make sure your tires are 36psi cold. Cars are sometimes delivered with less pressure.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 11-22-2016, 11:06 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
I don't know everything that determines how far a car will coast but I can tell you that in my experience, more weight gets you to coast farther with less decel. My Ram SRT had a curb weight of 5200lb with way heavier rims and I could coast twice as long as I can in the camaro. Camaro coasts noticeably less.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 11-28-2016, 11:32 AM   #8
jimitkr
I used to maintain 38 psi on my older 2LS; assumed that would be the right measure on the 2SS too. Maybe i'm wrong what's the recommended for better handling?
Old 11-28-2016, 11:33 AM   #9
jimitkr
In case you know, what's a good website to find used rims for my 2015 2SS?
Old 11-28-2016, 01:06 PM   #10
14Black1LESS
Depends on who you talk to, everybody's "recommendation" is different. Ive always ran 32 in the front and 30 in the rear cold.
2015, 2ss, camaro, rims
