![]() Drives: 2015 2LT SW RS A6 Join Date: Feb 2016
Check engine light on
My check engine light came on today, if oil life is below 25 % would that cause a cel. Car runs fine no noise or anything can't find anything wrong. But the auto start would not work, no messages shown in dic other than the cel. Any ideas what it may be?
![]() ![]() ![]() ![]() Drives: 2011 2SS Join Date: Mar 2015
I don't think it's anything to do with oil life. Remote start will never work with a CEL. Buy a code reader or go have the code read to see what it is
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
+1.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
Cope p0496 evap flow looks like a trip to the dealer is in my future.
![]() Drives: 2015 Convertible Camaro 1LT Join Date: Jul 2016
can't believe this... this just happened to my car as well. I have a reader and it read the same code P0496.It reads Evaporative Emission System High Purge Flow. got the same symptoms as you. Remote start does not work and car seems to run fine. drive it last night no issue but this morning i see that code.
Please keep us posted about your dealer visits. |
#6 |
![]() Drives: 13 Camaro Join Date: Oct 2016
The purge valve solenoid is the common cause for this on the 3.6l.
#7 |
And for what I have read this is by the engine correct?
#8 |
It is the valve that is in the way of removing the center ignition coil on the passenger side. It has the long bolt going from front to back.
#9 |
You have been a great help.I will take a look at this tonight or tomorrow and update you guys.
#10 |
This is covered under your bumper to bumper, have the dealership fix it.
#11 |
Unfortunately I'm out of the warranty 37,000
#12 |
Isn't emissions stuff warranty longer?
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
#14 |
I'll check with the dealer. Thanks guys
