Old 11-30-2016, 09:44 AM   #1
Superdonkey23
Superdonkey23's Avatar
Drives: BRM 2014 SS/M6
BTR Stage 3 cam installed
Finally got around to installing the BTR Stage 3 cam in my LS3 camaro. The drivability is damn near stock, and the sound is just perfect. No dyno as of right now but it will be on one soon. I highly recommend this cam to anyone wanting a lot more power while staying NA
https://youtu.be/iSf_C45TQBQ
NPP exhaust w/fuse pull, Stainless Power 1 7/8 LTH w/HF cats, CAI Intake, VMAX ported TB. Tuned by Phil at Tampa Tuning, 425Hp/418tq.
Superdonkey23 is offline   Reply With Quote
Old 11-30-2016, 11:08 AM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Sounds awesome! Might be idling a bit low on the rpm's, although I love it lol
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 11-30-2016, 12:29 PM   #3
xXSicSicSicXx
Drives: 14 1LE
it's always just an idle video. why not driving video with some WOT or something. most cams just sound the same anyways
xXSicSicSicXx is offline   Reply With Quote
Old 11-30-2016, 01:32 PM   #4
Superdonkey23
It might be a little difficult to make one with no go pro or anything, but I'll try it out.
Old 11-30-2016, 01:44 PM   #5
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
What's your full set up from top to bottom with this cam?
Like rockers, chain, oil pump etc.
Dmpsix is offline   Reply With Quote
Old 11-30-2016, 02:14 PM   #6
Bo White
Bo White's Avatar
Love mine.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-30-2016, 04:20 PM   #7
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Nice! I've heard they're the perfect cam to compliment FI as there's virtually no overlap between intake and exhaust. Enjoy your newly found power! Keep us posted post tune on how she drives.
Check out my build thread
Old 11-30-2016, 06:30 PM   #8
Superdonkey23
BTR .660 dual springs with titanium retainers, melling high pressure pump, upgraded pushrods, Katech C5R chain, ls2 dampener, 3 bolt timing gear, and stock tickers for now.
Old 12-03-2016, 06:59 AM   #9
stang stopper
Drives: 45th anniversary camaro ss
I have the BTR stage 4 with everything that you have,did you get the push rods from BTR and which ones did you get. This is my first build and I just want to make sure I do it the right way.
stang stopper is offline   Reply With Quote
Old 12-03-2016, 10:04 PM   #10
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
I have this in my garage as well! Will be installing in a few weeks can't wait! I plan to go FI way down the line and made sure this would work
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 12-05-2016, 11:38 PM   #11
Superdonkey23
Yes I got the chromoly pushrods from BTR. 7.4" length, and I measured just to verify. On a side note, this cam absolutely makes enough power to overcome the stock clutch. I took it out to the track, and the clutch stuck to the floor after my launch, trying to go to do the 1-2 shift.
Old 12-06-2016, 02:53 AM   #12
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
Yup, I've had that happen too
Soybeanrice is offline   Reply With Quote
Old 12-06-2016, 04:41 AM   #13
Bo White
Bo White's Avatar
My LS3 would do that stock all the way to 680rwhp. It's that sucky pressure plate that GM put in these things.
Totalled:
Old 12-06-2016, 06:31 AM   #14
Superdonkey23
I've heard that, and a number of other causes for it. Seems the only true fix is changing up to an aftermarket clutch. Any recommendations?
