Does anyone make a Tripple pillar gauge pod for the 2014 Camaro s? All I find are dual ones.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
![]() Drives: 2015 2LT SW RS A6 Join Date: Feb 2016
Don't any are commerically made, but there was a member here that made his own use the search feature u might be able to find his thread, i don't remember his user name, sorry.
![]() ![]() ![]() ![]() Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
It would have to be made, like the ones I have made in the past for a couple convertibles as they don't offer a pod at all. Your other option is a 3rd gauge in the vent hole as also shown in the pic.
There's your answer 2010_camaro have dealt with 2012LS3VERT and he is a strait shooter, he does excellent work have been to his shop before and seen some of his machining and it looked top notch. If i want something fabricated from scrath he is the guy i would pick to make the pillar pod.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
The user who made a triple was WHEELS-7207
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
I like the steering column gauge location better when racing the pillar gauges are out of my sight line
#7 |
Too much is never enough!
I went with the vent gauge, and I am running the dual pillar pod. I think I will change all of it and go with the triple pod that goes in the center of the dash.
Here is a website that has the triple pillar, but you have to wait for them to make it. http://www.ortizcustompods.com/chevrolet.html Hope this helps.
#8 |
LS3
I like that triple. I was looking for something kinda like that but for on top of the hood cowl kinda like my old TA had thought that'd be pretty sweet looking.
Lift Big, Get Big, Go Heavy, Or Go Home
