Old 12-04-2016, 11:07 AM   #1
strickland03
strickland03's Avatar
Drives: 2012 Camaro SS
Brake options for my SS
I have a 2012 SS, that's now a ZL1. I recently put Z28 wheels and would like to go bigger on slotted rotors. It currently has the Brembo brakes with 28k mikes. I love to drive it, but I don't race or track it so I'm mainly going for cost effective look of bigger rotors. What are my options? can I go bigger rotors with the same Brembo calipers?
strickland03 is offline   Reply With Quote
Old 12-04-2016, 11:14 AM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
SO the cost effective look? SO you did a LSA conversion?; do a zl1 brake conversion...?
And go some ceramic pads for dust..? Appearance for being cost effective to change out ones braking system....NOT SO MUCH.
Old 12-04-2016, 05:45 PM   #3
strickland03
I guess where I was going is can I go larger rotor with the brembo calipers I currently have? If I can't I'll likely just do largest slotted rotor.
Old 12-05-2016, 02:53 PM   #4
Abdi
Drives: 2013 1LE
I don't believe you can use a larger rotor with the OEM caliper. You might want to consider a two piece rotor from stop tech or racing brake if you want to gain some thermal capacity and great looks.
Abdi
Abdi is offline   Reply With Quote
Old 12-07-2016, 12:21 AM   #5
600hp-lpe
Drives: 2010
big brakes and cost effective don't mix. ANY big brake kit is 3K+ per axle. If they were anywhere cheap, everyone would do it.
600hp-lpe is offline   Reply With Quote
Old 12-07-2016, 12:41 AM   #6
hammdo
'It's an experiment'
hammdo's Avatar
This may be an option if you want 6 piston front brakes
http://www.camaro5.com/forums/showthread.php?t=418667
Agree though, nothing cheap for better brakes..
-Don
747 RWHP 794 RWTQ
Old 12-07-2016, 10:17 AM   #7
JusticePete
Drives: Camaro Justice
No you cannot run a larger rotor with a stock caliper.
