Old 12-05-2016, 10:34 AM   #1
Frostbite13
Frostbite13's Avatar
Drives: '13 2ls
Question torque
can somebody tell me the best mods to increase torque in my '13 2ls ?
Frostbite13 is offline   Reply With Quote
Old 12-05-2016, 10:58 AM   #2
camaro_power
camaro_power's Avatar
Drives: 2012 camaro LFX W/Boltons!
What do you currently have as for mods?
camaro_power is offline   Reply With Quote
Old 12-05-2016, 12:35 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
The best cost-benefit ratio parts are a cold-air intake, high-flow cats and a tune, each typically adding 10 - 15 HP and ft/lbs (although with each additional mod also comes diminishing returns, so doing all three won't get you a 30 - 45 HP and ft/lb gain); from there you can finish the intake and exhaust.
KillboyPowerhead is offline   Reply With Quote
Old 12-05-2016, 01:38 PM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Tough call. Your 2LS is tuned for gas mileage, so the gear ratio is pretty poor for acceleration (which I assume is what you want since you are specifically mentioning torque and not HP).
I'd say getting a throttle controller should get the feeling you want the fastest/easiest.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 12-05-2016, 06:07 PM   #5
Kenny Camaro
Drives: 2013 1LT RS Camaro
The Jacfab intake spacer is specifically for added torque in the lower 2/3 of the rpm range. I'm ordering one for Christmas!
Kenny Camaro is offline   Reply With Quote
Old 12-05-2016, 06:14 PM   #6
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
Which one is a better to do the ported intake manifold or the spacer for better torque? Thanks
cubamvp is offline   Reply With Quote
Old 12-05-2016, 06:53 PM   #7
Kenny Camaro
I don't think Jason is currently doing the intake porting any more, but the intake spacer is specifically designed for torque in crease. A cold air intake system does similar hp/torque increases as the ported intake manifold, so both work hand in hand to increase hp and torque on the intake side of the motor. To answer your question, the spacer is better for torque in crease
Old 12-05-2016, 06:56 PM   #8
Kenny Camaro
Changing your rear ending gearing, the ring and pinion gear, will give you a mechanical advantage increase in torque.
Old 12-05-2016, 07:48 PM   #9
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
Good to know man . Thanks for the great info.
Old 12-05-2016, 08:23 PM   #10
Kenny Camaro
You can email Jason at Jacfab and ask him about the mani. He may be doing some on a limited basis, never hurts to ask , all he can say is yes or no.
Old 12-05-2016, 08:56 PM   #11
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
That's very true . Doesn't hurt to ask. . Thanks man
Old 12-06-2016, 02:00 AM   #12
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Don't forget the oil tube extender if you plan to keep using the engine cover. I just bought mine in anticipation of picking up JacFab's spacer after the holidays.
Jazzzed is offline   Reply With Quote
Old 12-06-2016, 04:06 AM   #13
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Good point for people considering the spacer. I bought mine on eBay for about $8 shipped if memory serves me correctly. Factory GM part too. Believe it also fit the G8...
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 12-08-2016, 10:08 PM   #14
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
torque
+1 the intake manifold spacer on the Camaro intake was produced in an attempt to only make additional low to mid range torque.
The two parts compliment each other very nicely. The intake manifold spacer will gain you zero PEAK hp or tq, all of its gains are specifically made below about 5200 rpms, power and torque where it is usable EVERY day. The ported intake manifold builds on that to give you additional hp and torque below 5200 and continues to deliver it above that all the way to redline, see Dyno graph below
The blue line is a bone stock 2014 1LT V6 automatic, the red line shows the same car with only the intake manifold spacer, and the top maroon line shows the same car with only the spacer and ported intake manifold, with no other mods.
That said, I am sold out of spacers at the moment, and I am currently waiting for material to show up so I can make the next batch, but you can get them from Overkill. I should have more material to make the next batch next week. As for the ported manifold, I have taken a break from doing core exchanges and I am only selling new ported intake manifolds outright. Ie: if you want a ported intake from me, I will order a new manifold, port it, and sell it to you. I make zero money off of the new intake manifold itself, you are more than welcome to send me your own intake manifold for me to modify, or pick one up from a junkyard or eBay. I only charge for the labor and materials.
Each manifold comes with a new gm intake gasket kit, and free shipping in the continental US. Spacers come with new oring gaskets, no RTV sealant needed, and appropriate new hardware. I include an engine cover stud mount spacer to raise the stud up but if you plan to run the factory engine cover you will need to order the gm p/n 92068813 oil filler extension which is about $10 from a local dealer and sometimes cheaper online.
Jason@JacFab is offline   Reply With Quote
