Old 12-09-2016, 07:12 PM   #1
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Kudos to SquashPerformance!!!!!!!
Just want to give a shout out to Andy and SquashPerformance. I've had his dual 400LPH setup for 3 years now and about 15000 miles at 1281 rwhp. I recently started having some pressue loss issues......Andy minimized my down time.
Andy's/Squash customer service has been impressive. That's an understatement. Thanks Andy!
To those here adding big boost, you need big fuel. Squash will always be on my car!
BullF-16 is offline   Reply With Quote
Old 12-10-2016, 02:44 PM   #2
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Car sounds like a beast!
RealQuick is offline   Reply With Quote
Old 12-13-2016, 08:03 AM   #3
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
I loved my squash system, I recently maxed the system out thou and had to go a different route. But it worked flawlessly for 2 years running e85 thru it the entire time.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 12-15-2016, 09:05 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Just a question here, but what is the minimum amount of fuel you need to keep in your tank? I heard you needed to have a certain amount at all times, and could not let it run past that.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-15-2016, 11:10 AM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Squash uses a factory bucket. I've never had any fuel issues when it was low.
Old 12-15-2016, 02:43 PM   #6
Unreal
Drives: 2006 Z06
That being said, its always a good idea not to run super low on fuel as that is used to cool the pumps. I try to never go below 1/4 tank. No reason to stress the pumps for no reason.
Nick
Corvette Z06 -1200ish rwhp
Old 12-15-2016, 03:18 PM   #7
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Squash does use a factory bucket and I've ran it pretty low not being close to an e85 gas station without any problems. Andy is great to work with as well called a few times he was happy to answer any questions
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
