Old 12-12-2016, 11:19 AM   #1
Davidramirezii
Drives: 2010 Camaro LS
Seat belt issue
Hi all,
I recently had a driver's side seat and motor assembly from a 2013 Camaro swapped into my 2010 Camaro LS when my seat motor died last week. Seat works great now, however, my seat belt now does not fit into the new female end receiver. How should I fix this? I still have my old seat. Can I unbolt the original female receiver and bolt it into the new seat? Or would it be easier to change the male end of the seat belt? Is that possible? Thanks!
Davidramirezii is offline   Reply With Quote
Old 12-12-2016, 11:26 AM   #2
jd10013
Drives: 2012 camaro
your probably going to want to take both stock pieces and put back in. they aren't just seatbelts anymore. it's tied into your airbags and god knows what else
jd10013 is offline   Reply With Quote
Old 12-12-2016, 03:12 PM   #3
Blazer098
Blazer098's Avatar
Drives: 2015 Summit White SS
I'm assuming all seats are the same, but with my Recaros you can switch the female end which would be much easier. It's connected by one bolt on the side, and a wire which is connected to the sensor to check if you're buckled when driving. Not sure how easy changing the wire would be though.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
Blazer098 is offline   Reply With Quote
2010, 2014, seat belt, wrong
