Old 12-13-2016, 09:35 PM   #1
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
What are you doing to your Camaro this winter?
Even when you say you are done. It just keeps on going.
So what are you going to do to your car this winter?
stratman2SSRS is offline   Reply With Quote
Old 12-13-2016, 10:17 PM   #2
thino
thino's Avatar
Drives: 2010 Camaro 2SS/RS
3.91 gears, upper control bushings, Diff bushings, and coilover rebuild!!!!
LR NightFury Cam, 2" American Racing Headers w/ 3" ARH Catback, Cold Air Inductions Intake,
ZL1 6 Piston Brake Upgrade, Pedderized
thino is offline   Reply With Quote
Old 12-14-2016, 08:42 AM   #3
1meanls3
Drives: 2014 2SS/RS SIM
i was hoping to do an ecs kit but its not in the budget maybe next winter
1meanls3 is offline   Reply With Quote
Old 12-14-2016, 09:01 AM   #4
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
So what are you doing you sandbagger ?
tpower is offline   Reply With Quote
Old 12-14-2016, 09:30 AM   #5
BLU DUCE
BLU DUCE's Avatar
I might be done with mine. I haven't done any new mod in almost 4 months.
Old 12-14-2016, 01:00 PM   #6
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
somebody call 911 something happened to Spike
Old 12-14-2016, 03:37 PM   #7
BLU DUCE
BLU DUCE's Avatar
Going to be working on the 92 silverdo 454. Haven't really done anything to it in about 10 years. Started showing it a lot this summer. Took 6 trophies with it 2 best of paint. I don't know if you ever saw it before. I have a couple of pics on my Camaro build.
I have you done anything to the motor on the 1LE?
Old 12-14-2016, 09:54 PM   #8
stratman2SSRS
I think he did a little work under the hood, mostly show car stuff?
I'll show you next year at the track.
Old 12-15-2016, 08:55 AM   #9
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I may have a new surprise for you , maybe race you in the wifes vert jus sayen
Old 12-15-2016, 10:09 AM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Pulling the motor, and replacing all the bearings, seals, and rings. Then its off to the engine dyno, re installation, and finally chassis dyno for tuning.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-15-2016, 10:48 AM   #11
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Very cool let u know those numbers when finished
Old 12-15-2016, 10:51 AM   #12
1KillerSS
1KillerSS's Avatar
Numbers should be similar to what it is now, there is a little left in the fuel supply maybe enough to get it to 800whp, but that's about it.
Build thread
Old 12-15-2016, 04:48 PM   #13
NVERL8TE
NVERL8TE's Avatar
Drives: 1967 Camaro BBC, 2014 Camaro ZL1
I think I'm in the same boat, going to focus on the 93 454 this year. New fuel system, supercharger rebuild, and a new locker for the rear end.
NVERL8TE is offline   Reply With Quote
Old 12-16-2016, 07:46 PM   #14
luckynuts
luckynuts's Avatar
Drives: 10 ABM 1SS/00 Z28 Conv/14 SumWh 2LT
I'm going to put a trickle charger on the battery and cover it up............ I think
1 SS/RS 6Sp White Rally Stripes
luckynuts is offline   Reply With Quote
