![]() Drives: 2014 ZL1 Join Date: Jul 2016
Rear 18 DR setup
I have a price for 18 replicas and have been searching on the size and vendor for the drag radials.
So far I have narrowed the vendors to Hoosier M/T M/H In that order. Any specifics I am missing or raves about a particular tire and size? I used to have great luck on M/H on a BBC Camaro, but that's a totally different car. Thanks in advance DB |
![]() Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
I think all tires are different diameters as wel. M&H and MT Street 2- 28". MT ET street R-29" Hoosier-30"
So that'll play a factor, I have ET street R on my 18 replicas and they hook great at the track
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
i was going to use these primarily at the track, with some possible street time. I am keeping my stock rears for longer and frequent trips.
DB |
found these newer sized mh 345-35R18
http://www.mandhtires.com/M-H-Drag-Radials/345-35R18 Looks 28 inch so no fault lights, and saw one ss camaro post that said they fit, although the 30 inch hoosiers at nearly 100$ cheaper dont look bad either |
That's a small sidewall. My ET street R are 29" and have a 45 sidewall they are only 305 wide though.
#6 |
Good point forgot about the sidewall size, and that's key on these. The 30 inch hoosiers are looking better.
DB |
#7 |
![]() Drives: 2013 camaro zl1 Join Date: Feb 2016
Im running 305/45/18 nitto NT05 Rs on my replicas. No ABS issues
#8 | ||
35 means 35% of the tire width. .35x345 = 120.75 mm 45 in the MT ET Street is .45x305=137.25 mm so the 45 definitely has a taller sidewall but just don't go by that number alone.= because you gotta also consider the 305 width versus the 345 width. Auto trannies don't launch with as much shock as a manual so tire choice is easier (or less important). |
