Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 12-14-2016, 06:04 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
295/35R20 x 315/35R20 set up
Anyone find a good track tire with the following sizes:
295/35R20 (fronts)
315/35R20 (rears)
The Michelin PSS seem a bit pricy....
Was trying to find some Hankook's or something similar.
Mods:
Old 12-14-2016, 06:48 PM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Ive been running the Hankook Ventus V12s up front, loving them so far
SSEssence is offline   Reply With Quote
Old 12-14-2016, 06:52 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
295's???
Mods:
Old 12-14-2016, 08:17 PM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
You know that changing a 305 to a 315 or 285 to 295 won't make a difference noticeable at all right? Top of the line tire to run all around are R888s, they're going to be in 285/35ZR20 and 315/30ZR20. These fit stock rims perfectly and due to a slightly shorter sidewall, less than .5", they will lower the car a tad bit all around. Perfect super high performance road course and straight line tire. If you have the cash for them, then DEFINITELY do it. You could also look into NT01s by Nitto too.
And if you want to step down a bit in performance, then you're at an MPSS.
I'd go R888 if you have the coin.
Can'tHave2MuchHP is offline   Reply With Quote
Old 12-14-2016, 08:57 PM   #5
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Running 888s at the track, they have a new 888R also on tire rack
I will be doing the heat cycle option with my new set
Crash76 is offline   Reply With Quote
Old 12-14-2016, 09:24 PM   #6
Can'tHave2MuchHP
Drives: Fast
Do you mean R888 or is 888R a different tire? Second time I've seen someone put "888R" and wondering if I'm missing a tire.
Old 12-14-2016, 09:49 PM   #7
flipstyledsm22
Let's go fishing!
flipstyledsm22's Avatar
Drives: a car with 8 cylinders
I'm glad you brought this up KaBoom1701. I was contemplating this very thing, but opted to leave the sizes out because I didn't want to get flamed. I believe the sizes should give the ride height the same lift in the front and rear, while still providing clearance in the fender wells without rubbing.
The only problem I was running into was a lack of A/S in those sizes. Didn't want to have different tread patterns by having to go with two different brands.
Do it! And report back with your impressions on the change.
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
flipstyledsm22 is offline   Reply With Quote
Old 12-14-2016, 11:10 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Well according to tire rack the R888 are not available in the ZL1 tires sizes....
Mods:
Old 12-14-2016, 11:25 PM   #9
Crash76
Team 913
285/35R20
315/30R20
Dont search by car, search by size
Old 12-15-2016, 10:39 AM   #10
Can'tHave2MuchHP
Drives: Fast
I put the proper sizes that fit without issues in my post genius...Go by size not car.
285/35R20
315/30R20
Old 01-13-2017, 07:24 AM   #11
Travis104
Drives: 2014 ZL1
I have also been looking for tires. The tires will see abuse with autox events. I have been researching the R888 and the NT01. They are close in price, but does anyone have a preference on which is better?
Travis104 is offline   Reply With Quote
Old 01-13-2017, 09:06 AM   #12
flipstyledsm22
Let's go fishing!
A few members here are pitching the R888's as the best performers out there... plus a few pals of mine with GTR's swear by them too. If I could afford an extra set of wheels for tracking, I'd buy them.
Old 01-13-2017, 03:35 PM   #13
s/c ss
s/c ss's Avatar
Drives: 13 ZL1, 10 Silverado LTZ, Chopper
295/35R20 (fronts)
315/35R20 (rears)
I bought the MPSS's but I was looking at the Falken Azenis RT615K (championship proven street and track tire) or FK453 (dry and wet handling are almost 5 star).
s/c ss is offline   Reply With Quote
Old 01-17-2017, 08:42 PM   #14
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
Thumbs up
Just an FYI; This is how they are listed "Toyo Proxes R888R" racing tire DOT competition. I will try these this summer. Thanks for the info. I am currently running MPSS.
NW Sam is offline   Reply With Quote
