Old 12-16-2016, 11:41 AM   #1
pecothern
pecothern's Avatar
Drives: 2013 SS VERT
Help with Installing 2014 RS Headlights
Does anyone know where I can find a pinout for the plug on 2014 RS Headlight. I'd like to know which pin is Power for Halos, ballast power and the Hi beam shutter and are they all 12 volts?
pecothern is offline   Reply With Quote
Old 12-16-2016, 01:54 PM   #2
LeRoyDL
LeRoyDL's Avatar
Drives: 2015 SS Conv.
curious where / what you paid for the lights. if you find this pin out pls post back, seems like most have taken the gen5diy harness route.
LeRoyDL is offline   Reply With Quote
Old 12-16-2016, 04:23 PM   #3
Blazer098
Blazer098's Avatar
Drives: 2015 Summit White SS
I just did this swap and bought them here off another member. I paid $700 then bought the gen5diy harness for another $200.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
Blazer098 is offline   Reply With Quote
Old 12-16-2016, 04:29 PM   #4
LeRoyDL
LeRoyDL's Avatar
You did this to your 2015? I want to do the same (and the RS tails) on my 2015 2ss vert. nothing else was needed? How much work was it hour wise?
Old 12-16-2016, 09:06 PM   #5
Blazer098
Blazer098's Avatar
Yep on my '15. Only other thing I purchased was a new set of fog lights that were the same color as the headlights. Took me about 4 hours to swap everything out. Everything went smoothy, however you will need two people to remove the front bumper. Here's a picture of the results. Name:  IMG_3494.JPG
Old 12-18-2016, 10:37 PM   #6
pecothern
pecothern's Avatar
Car looks great Blazer thats what I'm hoping for soon
I found a pair on Ebay for 550$ and 50$ shipping. a bracket was broken off each of the lights but they had been repaired nicely with epoxy. I took them apart tonight and found there is a red and black wire going to the ballast yellow green and orange is the question in those three there has to be power for halos and the solenoid to open/close shutter for hi/lo
There are five pins
drivers side Looking into the plug is like this the "I"s are the 5 pins
I yellow I black to ballast
I orange clip on this side
I green I red to ballast
I would gladly buy the harness BUT my car is a 2013 SS2 that was stolen and chopped shop down to the frame even harnesses. it was rebuilt with a 2014 front cap with halogen lights. All the wires are cut spliced and soldered. ive been talking to GEN5 DIY they want me to cut up everything i have and go back and install 2013 connectors on everything so they can build me a custom conversion "plug and play harness" If i'm gonna chase these wires down and put connectors on them I am going to just build the harness with 2014 plugs. I have figured it out i believe. i posted it here. http://www.camaro5.com/forums/showthread.php?t=477190
I just need the plugs and to ID the orange green and yellow wires. I think I Can figure out the wires coming from the car. Thanks for you interest. i'm sure "someone" on here knows and could help me get the pigtails to plug into the 2014 lights
Old 12-19-2016, 03:37 PM   #7
pecothern
pecothern's Avatar
I believe i found the female connectors i need to add to my current GT150 plug to get five wires into the light instead of the 3 I have now here:
https://www.delcity.net/
83060 GT 150 Blue Cavity Seal, 18-16 Ga, Delphi 15366060 (10 MIN) In Stock 10 0.44
83818 Terminal, GT 150 Female, 22-20 Ga, Delphi #12191818 (10 MIN)
rs headlights
