Old 12-17-2016, 02:41 PM   #1
Adamadem
Drives: Saturn
Headers, HF Cats, CAI to NPP Sound
Hey Guys,
I've been doing research on the forum but only found a couple threads. What does out 1le sound like with headers, hf cats, cai to the npp system sound like. Hoping to avoid drone/rasp keeping the factory npp system.
Adamadem is offline   Reply With Quote
Old 12-17-2016, 06:22 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I can only respond to my high flow cat's as.......perfect. I would do it all over again!
cornerspeed92 is offline   Reply With Quote
Old 12-17-2016, 06:24 PM   #3
Clarkstar
Clarkstar's Avatar
Sounds awesome! I love mine
Clarkstar is offline   Reply With Quote
Old 12-17-2016, 09:09 PM   #4
Adamadem
Drives: Saturn
In case I think it's too loud, could I add resonators to the exhaust. If so which type would fit? Also, I don't want to add an x-pipe or resonated x-pipe. I want to keep the stock h-pipe in place.
Old 12-17-2016, 09:50 PM   #5
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
It sounds really good IMO. Its the setup I had before I tore everything out for turbos. With npp I just had a 3-way switch to have the npp flaps always open/always closed/or function like stock so when I wanted it quite I just closed the flaps and it was pretty tame. Open them up and get on the gas and it screams.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 12-18-2016, 08:10 AM   #6
SSmitch
SSmitch's Avatar
Drives: 14 2SS/RS/1LE
Originally Posted by Adamadem View Post
Hey Guys,
When you add headers, HF Cats, CAI the NPP exhaust when in the closed position it will be louder than stock but it doesn't drone and sounds better, nothing annoying. IMO
When it's in the open position it changes to a really aggressive sound note, and it will drone some if you're running at a constant speed.
I've heard many combinations of exhaust set ups but this is my favorite sounding with the LS3, the only thing I plan to do different is add a 3 way switch so I can eliminate the loud start up.
This is a before and after having mods done.
100% Stock:
With Mods:
6/17/22 UPDATE:
SOLD W/4900 Miles to Berger Chevrolet
Grand Rapids, MI
2014 Camaro 2SS/RS/1LE
Livernois Motorsports:
Ported Heads, TB & Intake.
2 R Max Cam (W/upgraded dual valve springs & pushrods)
Kooks 1 7/8" SS Headers, HF Cats & NPP Exhaust
MSD Wire Set/Roto-Fab CAI
Elite Oil Catch Can/GM Oil Catch Can (Clean Side)
Custom Tune 93 Octane
500 WHP 453 WTQ
Sound Bite:https://www.youtube.com/watch?v=CGBUYF1Ce9Q
Dyno Run:https://www.youtube.com/watch?v=BPE6DrtnVfo
SSmitch is offline   Reply With Quote
Old 12-18-2016, 09:41 AM   #7
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Absolutely perfect! I have Kook HFC's, Kooks LTH's and a CAI with NPP, and it has no drone, sounds great at idle, and fantastic at WOT.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-18-2016, 01:32 PM   #8
Adamadem
Drives: Saturn
Olddudesrule, do you mind posting a sound pic? I want to hear one with just those mods on it.
Old 12-18-2016, 01:50 PM   #9
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
I had SP 1 7/8 LTs with HF cats to NPP. It sounded pretty decent. Wish it would have been a little louder. I later deleted the HF cats and added 3" SW retrochamber quadtip catback. Not much of a difference in sound to be honest, just added drone.
ZYBORG is offline   Reply With Quote
Old 12-20-2016, 02:26 AM   #10
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Hey Guys,
My 1LE with Z/28 cold air kit, ARH LT headers to HF cats, ARH X-pipe to factory NPP. Also has cam/heads, so a lope to the idle, but will give you an idea on volume. Fairly loud if NPP is open. I use the 3-way NPP switch for quiet time. But, open or closed there is no drone and no rasp.
Video on YouTube. Link below. Sub-woofer Recommended.
https://youtu.be/nIc-AXW3_aM
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 12-21-2016, 12:34 PM   #11
MBaseman
Drives: 2015 2SS/RS/1LE
Another vote for perfect sounding, especially if you add an exhaust controlller for the NPP
MBaseman is offline   Reply With Quote
Old 12-24-2016, 02:49 PM   #12
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Tuning the Sound instrument
Hey Guys,
To kick things off, buy a quality 3-way controller from Forza, AND THEN, work your way front to back, and NOT rear of car to the front, or you will potentially miss the mark through bad hypothesis, and regret it once your out_of_pocket funded $$$ experiment ends.
Controller > CAI/TB/Intake > Headers > Cats > ......
Camaro Dude is offline   Reply With Quote
Old 12-25-2016, 12:24 PM   #13
cincidlr
Drives: SS1LE
have a 13 1LE w/ stainless works long tube header, CAI and the NPP. Removed the cats and lead the ecu remapped when the headers were installed and never disable the NPP. I love the sound! Reasonably quite under 3K but once you hit 3K, it ROARS! The majority of people who hear it, (keep in mind these are track people) luv it.
cincidlr is offline   Reply With Quote
Old 01-11-2017, 08:52 PM   #14
Adamadem
Drives: Saturn
Just had the Headers and High Flow cats installed. Sounds great in terms of exhaust. Is it normal for Headers to make more noise in the cabin. It is not super loud but does increase with acceleration. A little music or opening the windows eliminates it. I think it is the pulse of the exhaust that I can hear.
