Old 10-16-2009, 11:58 PM   #1
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
L99 3-4 Shift
Has anyone with a tune noticed that the 3-4 shift is significantly weaker/slower than all others, including 4-5 and 5-6? I am being picky because it is still better than stock, but it sucks compared to the rest.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 10-17-2009, 01:32 AM   #2
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
Haven't noticed.. when you had your tune, was the shifting tweaked at all?
Number_9 is offline   Reply With Quote
Old 10-17-2009, 09:59 AM   #3
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
My tune is very aggressive. 200 Psi and minimal times under adaptive learning. The 3-4 shift is simply weak compared to the rest. My shift points are set to 5900-6000. I think the tranny is mechanically not able to match the rest of the shifts. I get scratches 1-3 and then 3-4 falls way short.
11.39 @ 118 510 DA
Old 10-17-2009, 10:09 AM   #4
jamesfl
BAD 4SS
jamesfl's Avatar
Drives: 2010 2SS/RS with ground effect
Just told my tuner the EXACT same thing
I thought it was just mine. It is not that bad but I can definitely feel the difference at the track.
Procharger P1, Kooks LT, Corsa Cat-Back, AEM Meth injection, 2800 Stall, BMR trailing arms, DashDAQ computer, etc....
jamesfl is offline   Reply With Quote
Old 10-17-2009, 12:48 PM   #5
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
I honestly think it is an internal issue on how the 3-4 shift takes place. Maybe transgo will have a quick spring fix for it. I know they do not have a kit for this tranny yet, but they are working on one. From the attachment I would assume the 4-5-6 clutch pack assembly is the weak link.
11.39 @ 118 510 DA
Old 10-17-2009, 03:35 PM   #6
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
How do you like your converter so far...I am going to test one for him also.
11.39 @ 118 510 DA
Old 10-17-2009, 03:37 PM   #7
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
What are your mods? I think I am simply over-powering the tranny like jamesfl.
11.39 @ 118 510 DA
Old 10-17-2009, 03:38 PM   #8
rodimus prime
Drives: Cargo van.
Yeah my 3-4 is weak too. My 1-2 and 2-3 are great. My 4-3 downshift scares the bejesus out of me.
Car has a yank 3600 too.
rodimus prime is offline   Reply With Quote
Old 10-17-2009, 03:43 PM   #9
jamesfl
BAD 4SS
jamesfl's Avatar
Only 3 runs so far on the converter, took a ten off but I was only pushing 5.5 psi so it was probably 2 10ths. Now I have 8.5 psi, meth injection and 16 lbs drag rims with M&H tires on order. I should be out again in about 2 weeks.
Old 10-17-2009, 07:28 PM   #10
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Sweet keep us posted
11.39 @ 118 510 DA
Old 10-17-2009, 07:30 PM   #11
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Have you been able to log your downshifts. Hopefully your not flaring the tranny. A flare, especially on downshift, could kill a tranny fast.
11.39 @ 118 510 DA
Old 10-17-2009, 07:50 PM   #12
rodimus prime
Drives: Cargo van.
What the hell is flaing the trans?
Old 10-17-2009, 08:51 PM   #13
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Flare is when the transmission slips just before shifting. If you watch your tach, you'll see your rpm's increase suddenly just before the shift occurs. The best way to check for this is with a data log.
11.39 @ 118 510 DA
Old 10-17-2009, 09:22 PM   #14
jamesfl
BAD 4SS
jamesfl's Avatar
Dash DAQ
look it up I just installed one from Innovate, logs upto 8 parameters to a sd mem card. I have it with a wideband sensor and MAP sensor plus everything you get from the OBD2 connection(50 params).
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 01:41 PM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
Black LS3 + L99 emblems and V6 shift plate inside dragonZ28 Cosmetics and Lighting Modification Discussions 2 07-21-2009 07:04 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
