Old 12-21-2016, 02:01 PM   #1
onegoofydad
Drives: 2014 Camaro 2SS
Worst XM Antenna...Ugh...
Ok maybe its not the Antenna, maybe its some other sub point of the XM Service. But I have never had a car loose signal so much. I can be sitting next to a lifted truck and loose signal.
Today as tractor trailers drove by me....it would fuzz out.
Anyone else experience this, looks like in my search plenty of people have reception issues. Not sure if anyone ever found a fix.
2014 Black/Black Camaro 2SS RS L99, CAI Intake, Speed Engineering LTH. Jannetty Tuned.
onegoofydad is offline   Reply With Quote
Old 12-21-2016, 02:11 PM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
We loose it for a second under some overpasses, and when the coastal trees cover the road. Its the first car we have had with it, so I guess it does not bother me because I thought it was normal.
gajagfan is offline   Reply With Quote
Old 12-21-2016, 03:55 PM   #3
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Goofy, yours may have a problem... mine is like Gaga's, it only loses signal under some overpasses, and occasionally due to terrain, like heavy tree cover or deep canyons.
If you are still under warranty, maybe they can do something... when you go to the dealership, be sure to park next to a lifted truck or a building, just so you can demonstrate the failure!
Scalded Dog is offline   Reply With Quote
Old 12-21-2016, 05:18 PM   #4
ThisGuyDrives
Drives: 2014 Ashen Grey Metallic 1LE/1SS/RS
Definitely a problem. All I listen to in my car is XM and it comes through great.
Cold Air Inductions Intake
SPEC Stage 1 Clutch
BMR 1.4" Springs
Borla ATAK Catback Exhaust
Kooks 1 7/8" LT Headers w/ HF Cats
Last dyno tune was with just intake and catback exhaust did a 401/379.
ThisGuyDrives is offline   Reply With Quote
Old 12-21-2016, 05:21 PM   #5
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I though the same thing. When I drive down roads with trees on either side it cuts out. worst I have ever seen. I avoid certain roads now cause I hate to loose the service.
JD555 is offline   Reply With Quote
Old 12-21-2016, 08:08 PM   #6
littlefielc
Drives: 2013 convertible Hot Wheels
Mine cuts out for no reason sometimes. Oddly it seems worse when the weather is nice.
littlefielc is offline   Reply With Quote
Old 12-21-2016, 09:05 PM   #7
audiowhiz
audiowhiz's Avatar
Drives: 2005 Corvette M6
No issues with mine other than the normal underpass stuff.
audiowhiz is offline   Reply With Quote
Old 12-21-2016, 09:52 PM   #8
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
We've had xm for awhile now and had the convertible Camaro two years. It's just the last six months that my reception had been bad. I hav one intersection that's wide open, no bridges or buildings, and it cuts out there every day.
Whoomba is offline   Reply With Quote
Old 12-21-2016, 10:11 PM   #9
ThisGuyDrives
You know you can call XM and have them refresh the signal. I had the problem once in my Malibu and that fixed it.
SPEC Stage 1 Clutch
BMR 1.4" Springs
Old 12-21-2016, 10:30 PM   #10
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I only ever lost it when I went under an overpass. When it decides it wants to work haha. When I bought the car in August I had it for about a month and loved it. Then one day it said channel unauthorized. So I figured a free trial I apparently had was up and that was the end of it. But about a month later my girlfriend clicked the preset I had for it and I had it back! Enjoyed it for about 3 more weeks and now it's said channel unauthorized ever since haha. I check it about once a week to make sure it hasn't come back again, but who knows whats up with it
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 12-22-2016, 08:32 AM   #11
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Mine does seem a little more sporadic lately. BTW, you lose a signal, not 'loose' one.
Moto-Mojo is offline   Reply With Quote
Old 12-22-2016, 10:57 AM   #12
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Yeah, they keep giving a free trial with the hope that you buy it.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-23-2016, 12:23 AM   #13
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
I never lose signal, not even under overpasses. I think the only place I may not get signal is when I have my car inside our shop, and I'm not 100% sure on that, I may actually get signal in there too.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 12-23-2016, 03:42 AM   #14
redcoats1976
i lose signal under overpasses,or in my garage sometimes.
