Old 10-17-2009, 11:56 AM   #1
prfireman
Drives: 1969 Pontiac Firebird
ENGINE light on for 4th time in this Month
3 weeks ago engine light on, reduce power, and traction control
turn off 30mins later back to norm
on Oct. 9 same thing drove it to dealer she stayed the weekend, dealer states problem fixed, now Oct 17th remote start one minute and shuts off, all the same marks, left it sit for 2 hours, only Engine light on
Oh I just installed a Corsa cat-back on Oct. 14 it should have nothing to do with it
Day 1 at Dealer Service
1977 check eng light and reduce power message are on. checked codes. found 5 codes. co242-ecm indicated traction control malfunction, p2122- app senor 1 circuit low voltage, p2138-app sensors 1 and 2 not plausible, B0233- air flow control circuit short to battery, B0408 main temp control circuit to battery. trace codes c0242, p2122 and p2138 to rubbed through wires at the throttle body. repaired wires.
Day 2 at Dealer Service
p21211 code, ordered APP senor (2 to 5days for part)
At dealer cool, new part comes in they going to fix it, Service guy comes out all fixed cool let me hurry back to work cool here I go, WTF same crap different day, turn around drive back inside a start a Sh** storm, Fing thing did it again, but we fixed the code a AAP, I call GM they tell the dealer run a full diag. before you replace the ECM, now waiting for my car again, IF THEY WOULD HAVE LISTEN TO ME FROM THE BEGINING, he said those forums are no good for info we look at GM only.. yeah now I am waiting for a new ECM
prfireman is offline   Reply With Quote
Old 10-17-2009, 12:03 PM   #2
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
What did the dealer say they did to fix it? Can Onstar tell you what the engine code is?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 10-17-2009, 12:17 PM   #3
prfireman
Dealer said it was a module (questionable) and wires on electronic gas pedal
They also said they did the A/C recall since a code came up for that
I have no idea what codes were shown, dealer didn't say
Service dept. closed today, if now it will be back in there
Old 10-17-2009, 12:51 PM   #4
tones2SS
tones2SS's Avatar
Thumbs up
Can you try Auto Palace or a car store of some sorts? They have the hand held OBD reader, (On Board Diagnostics) that can read the code for you.
GOOD LUCK!!
Old 10-17-2009, 02:00 PM   #5
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
Are these cars OBDII or OBDIII? I have Autotap from from 4th gen, just wondering if that still works on these cars?
Back in the Game.
Bear is offline   Reply With Quote
Old 10-17-2009, 08:02 PM   #6
djsnoflake
Faith Keeper
djsnoflake's Avatar
Hey check your intake. If it is loose anywhere or the airbox didn't close all the way, your MAF can go cattywompas and throw the engine/service traction
Old 10-17-2009, 08:07 PM   #7
MyNewSolstice
MyNewSolstice's Avatar
Drives: 06 Solstice
is there any sensors on the exhaust? could they be loose? usually the SEL light is related to an airflow issue most often... have you done an oil change? did they remove your air filter...Once they actually messed up the sensor on my car by doing that.
2006 Solstice Z0K
1978 Camaro Z28
1978 Corvette 350/220HP SOON TO BE LS2
MyNewSolstice is offline   Reply With Quote
Old 10-17-2009, 08:08 PM   #8
MyNewSolstice
Drives: 06 Solstice
I believe it is not OBDII Not sure if it is straight up OBDIII
2006 Solstice Z0K
1978 Camaro Z28
Old 10-17-2009, 08:09 PM   #9
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
if it worked on a 4th gen it will work on the 5th. Both are OBDII
lawdogg149 is offline   Reply With Quote
Old 10-17-2009, 08:34 PM   #10
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Go to an autoparts store and get the code pulled. I'm dealing with a P3028 (knock sensor)...thought it was bad gas but it keeps coming back...it's time for a trip to the dealer.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 10-17-2009, 09:06 PM   #11
GQ4Life
Drives: 2010 Camaro SS LS3
try race gas.. see if u still get it...
dealer still cool with your mods?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-19-2009, 02:03 PM   #12
prfireman
The code they have now is P2122
They orders a APP senor
I need to find my other paper work, to see what code came up
Old 10-19-2009, 02:05 PM   #13
themossman
themossman's Avatar
If it's a bad knock sensor....the mods wouldn't have cause it. If is isn't, I'll probably have to pay for the diag fee...
Current Summary:
Old 10-19-2009, 04:00 PM   #14
prfireman
Just updated my info
codes and repairs are stated on top
Check Engine Light 3GPa Tuning / Diagnostics -- engine and transmission 0 10-15-2009 10:02 PM
CHECK ENGINE LIGHT camdriver98 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 08-24-2009 03:11 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
