Old 12-24-2016, 12:00 AM   #1
2ndHump
Drives: FrostBite
After market exhaust ?
Which exhaust would you get on your ZL1.. I had flowmaster super 44s on my SS.. what sounds beautiful on a ZL1
2ndHump is offline   Reply With Quote
Old 12-24-2016, 12:03 AM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Headers and the npp original exhaust
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 12-24-2016, 08:42 AM   #3
d454brisson
Drives: 2014 ZL1
Honestly, headers no cats sounds crazy with the NPP valve left open. Doesnt seem worth changing the back half when you get so much value from just adding headers.
d454brisson is offline   Reply With Quote
Old 12-24-2016, 02:34 PM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Yep, like I said in your other thread...
Headers + No Cats + The stock exhaust (NPP) sounds great, changing no cats to high flow cats tames the sound a bit.
If you want a different sound than the NPP has which is naturally a bit high pitched I think, you CAN buy a cat-back system from a few companies, but I would highly highly recommend Corsa's ZL1 system, it's around 1300$. Look up some YouTube videos of it.
You're best off to buy the Headers and no Cats first, see how you like it, and if you feel like you need a different system, then go for the Corsa.
Can'tHave2MuchHP is offline   Reply With Quote
Old 12-27-2016, 11:37 AM   #5
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
I had a muffler shop cut off the mufflers and fabricate two exhaust tips, splicing one into the other so it looks like stock, using stock hangers, for $400. It sounds really good to my ears. And to go back to original would be easee/peeze.
rmcbee is offline   Reply With Quote
Old 12-27-2016, 09:04 PM   #6
DerrickG
DerrickG's Avatar
Drives: 2013 Camaro ZL1
I would have to agree with the others, I have kooks long tubes with high flow cats option and it sounds great with the stock NPP exhaust. I've looked into getting a catback and Corsa is the name most mention to me but I decided to put the money elsewhere and stick with the stock exhaust for now.
Rotofab CAI, 2.55 upper, 8.6 lower, heat exchanger, ID850 injectors, boost a pump, custom ground comp cam, kooks long tube headers with high flow cats, E85 conversion flex fuel, nkg plugs, NT05R Drag radials, 712 rwhp built by Lethal Performance. Instagram Gonz_ZL1
DerrickG is offline   Reply With Quote
Old 12-27-2016, 10:08 PM   #7
rdemarce
Drives: 2013 ZL1 A6
Headers and not cats sound great on the car. I just had that put on mine and it sounds really good.
rdemarce is offline   Reply With Quote
Old 01-02-2017, 09:48 PM   #8
Noble
Noble's Avatar
Drives: 2013 Chevy Camaro ZL1
Stainless Works all the way I got the full exhaust with high flow cats. Don't regret it at all. But I'm going catless soon anyways just to be louder and to prevent my cats from melting and destroying my engine.
Here's a video I made showing off the exhaust: https://youtu.be/ts8QTltPJ6c
Noble is offline   Reply With Quote
Old 01-02-2017, 10:20 PM   #9
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Nice video, but to loud for me...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 01-03-2017, 09:54 AM   #10
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
I went with the Dynatech and high flows and added a DIY Mild to Wild for the NPP. I leave it wide open 90% of the time, if you want a little quieter, just force the flaps closed.
Sounds great.
NVRL8 ZL1 is offline   Reply With Quote
Old 01-03-2017, 11:33 AM   #11
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
I have a set of ARH 1 7/8 without cats for sale...PM me
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
G Money is offline   Reply With Quote
Old 01-03-2017, 01:08 PM   #12
flipstyledsm22
Let's go fishing!
flipstyledsm22's Avatar
Drives: a car with 8 cylinders
Awesome vid Noble
That wicker bill looks as good as a nice set of titties! Where did you buy it from?
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
flipstyledsm22 is offline   Reply With Quote
Old 01-05-2017, 05:06 PM   #13
Buckley12
Drives: 2013 zl1
I have corsa on mine z and honestly even the cops love the sound of the car. YouTube will give a good idea but it's nothing like being in person
Buckley12 is offline   Reply With Quote
