CamaroFans.com
GMPP is interested to know what performance parts you would like to see offered.
Fill out the survey by the end of 2016 and qualify for a gift certificate drawing. https://www.onlineconsumersurveys.co...&as=yg9HI8IC5u ^^^Hopefully this link will continue to work. Hope to see more from them as this progresses. Now's your chance to get your 2 cents in.
![]() Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
That link brings me to a page that says my response tho this survey has already been received.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
![]() Drives: 2015 2LT SW RS A6 Join Date: Feb 2016
+1 bad link ?
#4 | |
CamaroFans.com
![]() ![]() ![]() ![]() ![]() ![]() Drives: Black L99 2SS/RS Join Date: Mar 2014
I filled it out.
Quick bit of advice, I highly recommend everyone fill out either "Very likely" or "Very unlikely". When survey information is gathered .... filling out one extreme or the other helps gather more precise information, it's hard to gather info when someone fills out things like "unsure, neutral, somewhat likely, etc. " |
#6 | |
CamaroFans.com
#7 |
#8 |
CamaroFans.com
success then... Thanks!
#9 |
Neither worked for me.
2011 Camaro SS
1999 Camaro SS 1969 Camaro http://www.fquick.com/csmith4153 https://www.youtube.com/channel/UCKH...lQFJSUtgrNEY7w |
#10 |
![]() Drives: 2013 2SS/RS Join Date: Nov 2015
Can't use either
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#12 |
You guys are probably using Google Chrome or Firefox
try switching to internet explorer, I'm at work right now and only have access to IE. The web browser is probably what's doing it. |
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
2011 1SS/RS LS3 CGM
#14 |
CamaroFans.com
It seems the link is good one time. I refreshed it and after Dmpsix used it I don't think it's valid anymore.
Posted a new link. Give it one more shot. |
